help!!!
Old Sep 17, 2004 | 02:13 PM
tom's Avatar
tom
Default help!!!
ok i have a 2003 dodge neon se. i did't realize this problem when i bought my car until i wanted to lower it. if you look at my car from the front you will see that underneath on the passenger side that something is hanging down. it either looks like a motor mount or maybe strut. does anyone know and if, how do you fix it. i'll try to get a pic
Old Sep 17, 2004 | 03:30 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: help!!!
Um...its not a strut. I'd say get a picture. Sure its not one of those plastic splash shields? I'm lowered and I don't have anything wierd hanging down on the passenger side.
Old Sep 18, 2004 | 02:00 AM
TJW815's Avatar
TJW815
Default RE: help!!!
i see if it's only held on with a bolt or two, no lines coming in or out. and no belts attached, rip it off and see what happens, thats just my opinion, I wouldn't try it though if I were you. But on my 03 se i dont' see anything hanging that shouldn't be there.
Old Sep 18, 2004 | 01:48 PM
casper's Avatar
casper
Default RE: help!!!
Hanging down in the way of lowering the car?? probally just a splash guard. Post a pic.
Old Sep 20, 2004 | 04:31 PM
tom's Avatar
tom
Default RE: help!!!
i had a guy from dodge come over to my house and we were looking at it and the problem was who ever did the motor swap to my car tightned one of the bolts to the motor mount to hard that the bolt snaped. cauising the motor to tilt towards the passenger wheel. the piece that was haning down was the splash guard. and the thing thta was pushing the splash guard was the whole pully assembly and stuff.
Old Sep 21, 2004 | 12:40 AM
casper's Avatar
casper
Default RE: help!!!
Thats not good. You can just replace the MM and that should fix it.
Old Sep 21, 2004 | 03:13 PM
tom's Avatar
tom
Default RE: help!!!
so all i had to do was take this piece of the broken bolt out and but a new one in.
Old Sep 23, 2004 | 06:36 AM
casper's Avatar
casper
Default RE: help!!!
I would have to see a picture to be sure, but from what your saying I would replace the entire MM, from the part that mounts to the motor to the part that mounts to the body, not just the inserts. Where is the bolt broken?
Old Sep 23, 2004 | 01:20 PM
tom's Avatar
tom
Default RE: help!!!
if you look in the wheel well of the passenger fron tire you will see like 2 holes each for the 4in bolt well one of them was broken from the motor swap or broke form to much tension. so the mount is fine but the bolt broke which only costed 6 bucks to fix. but i am gonna but ne mm what do you suggest
Old Sep 24, 2004 | 06:00 AM
casper's Avatar
casper
Default RE: help!!!
oh, ok thats cool, any problem you can fix for $6 and a little time isn't too bad.
