eBay products questions
Old Oct 5, 2004 | 02:21 PM
techmanbd's Avatar
techmanbd
Default RE: eBay products questions
Is it considered HAI because of where the Air Element ends up? too close to the motor?
Old Oct 7, 2004 | 12:00 AM
Altima_wb's Avatar
Altima_wb
Its called a HAI cause it takes in hot air from the engine compartment, where as a cai takes cold air from out side the engine compartment.
Old Oct 8, 2004 | 03:15 PM
casper's Avatar
casper
TJW where does you aem pick up air? From inside the engine compartment or lower down by the ground?
Old Oct 8, 2004 | 04:11 PM
sauceboy's Avatar
sauceboy
the 2nd gen intakes pull from inside the fender well. even the stock intakes.
Old Oct 8, 2004 | 06:45 PM
TJW815's Avatar
TJW815
casper, its got a tube that run from the intake manifold to the TB, then from the TB to the inside of my fenderwell, outside of the engine compartment
