1995 Neon Sport Shifts to Neutral From Drive
Old Sep 26, 2004 | 03:02 PM
alexrusekrusek's Avatar
alexrusekrusek
Default 1995 Neon Sport Shifts to Neutral From Drive
I am looking at buying this 1995 Neon Sport, and the owner says when he test drove it, and went on the gas a bit it would sporadically shift from Drive to neutral.
It's an automatic.
Anyone know what the problem could be?
Old Sep 26, 2004 | 04:20 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: 1995 Neon Sport Shifts to Neutral From Drive
Could be the kickdown cable on the transmission. It could be stuck.
Did he tell you if the gear shift itself moevs on it's own? When exactly does it do it, under heavy load or just randomly?
I've seen this before, it's susually th ekickdown cable ont he tranny itself sticks. Try cleaning it and greasing it with something. That should correct the problem.
Old Sep 26, 2004 | 04:47 PM
alexrusekrusek
It happens under heavy load, when you start traveling at a higher speed.
The actual gear shifter moves on it's own to N.
Where can I find this cable, how do I get to it and so on. I am getting the car for only $1000, and seems like a good deal if this is a easy fix.
Is there something big that could be causing the problem?
Old Sep 26, 2004 | 05:11 PM
Cr@zy Squ33
No, it does sound like the kickdown cable is stuck. Take it apart and clean it.
Old Sep 26, 2004 | 10:54 PM
casper's Avatar
casper
its near the throttle cable and goes down to the trans I believe.
Old Sep 26, 2004 | 11:02 PM
Cr@zy Squ33
Yes, that's where it is.
I've already shown him pics of it. Though. Hopefully he gets it fixed with no issues.
Let us know will ya.
Old Sep 26, 2004 | 11:17 PM
casper's Avatar
casper
oh, I didn't see any pics in the posts.
Old Sep 27, 2004 | 12:10 AM
Cr@zy Squ33
Yeah, he IMed me earlier. I showed him a few.
