04 jolt is this normal?
Old Oct 27, 2004 | 07:41 PM
paul79usa's Avatar
paul79usa
Default 04 jolt is this normal?
i just bought my g/f a 04 neon es with 20,000 mi, and when i shift the car into drive fron neutral or nuetral into drive or drive to park, it shifts rough almost a jolt? is this normal, do neons just **** into gear rough or is it something more serious? keep in mind the car only has 20k miles. any info would be great thanks -Rob
Old Oct 27, 2004 | 09:04 PM
paul79usa's Avatar
paul79usa
Default RE: 04 jolt is this normal?
any 1?[:-]
Old Oct 27, 2004 | 09:51 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
It would be helpful if you could tell us if it is an automatic or manual?
Old Oct 27, 2004 | 10:20 PM
paul79usa's Avatar
paul79usa
automatic
Old Oct 27, 2004 | 10:28 PM
Cr@zy Squ33
When was the last time it was serviced? The transmission I mean.
Old Oct 27, 2004 | 11:45 PM
lonasindi's Avatar
lonasindi
I guess it depends on how big of a jolt. A little bit of a jump is normal for any smallish automatic, I'm thinking. If it's just a little blippish kinda deal, I'm sure it's fine. But if it's shaking very hard, or if there's some kind of noise, that would probably be quite bad.
Old Oct 27, 2004 | 11:47 PM
paul79usa's Avatar
paul79usa
I dont think ever. I tried other neons and they shift rough also but idk if this is normal
Old Oct 28, 2004 | 06:09 PM
casper's Avatar
casper
ther is gonna be a little jerk, jolt when you put it in and out of gear, it should not be any different than any other ATX. If you think there is something wrong, take it to a good trans shop, have them service it, adjust the bands, fluid and filter change, make sure they use the correct fluid.
Old Oct 28, 2004 | 11:28 PM
morningpride's Avatar
morningpride
A little CLUNK is normal, A big SLAM is bad,
I can't imagine that a 04 w/20k on it would need a ATXservice tho....
What mileage do they recomend it at???
Jeff
Philly
Old Oct 28, 2004 | 11:30 PM
Cr@zy Squ33
15K.
