Lowering a Neon
Old Nov 22, 2004 | 02:50 AM
nightstreetneon's Avatar
nightstreetneon
Default RE: Lowering a Neon
what do you need to do it yourself besides a spring compressor?
Old Nov 22, 2004 | 02:56 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
ORIGINAL: NeonDriver01
Yea my older brother works at a garage and they charge 50 an hour just for labor...but on the plus side i get all my upgrades and stuff put on for free at home cause he can borrow engine pullers and all that good stuff...
On a different note i just bought new 16" wheels that i will be putting on in the spring and i just needed to know what i will need to get the speedometer accurate cause i know with larger tires the speedometer wont be accurate what would i need to buy or adjust??
thanks!
What you need to do is measure the circumfrence of your stock rims with stock tires on them. Then when you go to look at tires find the one that closely resembles the circumference of your stock tires.
So, basically you'll be getting lower profile tires as they will closely match your stock tire size.
Old Nov 22, 2004 | 04:55 PM
LowSlowNeon's Avatar
LowSlowNeon
They have these online already....no need to measure your stock rims w/tires.
http://www.miata.net/garage/tirecalc.html
You put your stock settings in there and then the new size you're going to. Then you can change it to get it as close to the stock rim/tire diameter which will keep your speedometer reading the same.
Old Nov 22, 2004 | 11:11 PM
fraust's Avatar
fraust
i just bought a 99 neon rt 3 weeks ago and was already lowered. i dont know how it was done but the car rides extremely rough like to the point where you get sick at times. what could the problem be?
Old Nov 22, 2004 | 11:16 PM
Cr@zy Squ33
The problem could be that its lowered.
When you change the suspesion for handling you lose comfort. If you don't like the way it rides, bring it back to stock specs.
Old Nov 22, 2004 | 11:19 PM
fraust's Avatar
fraust
how can i make it a little less bumpy. maybe new struts?
Old Nov 22, 2004 | 11:21 PM
Cr@zy Squ33
New struts can help it ride a little less rough. But it'll still ride rough.
Old Nov 23, 2004 | 12:02 AM
98Neon4Door's Avatar
98Neon4Door
struts normally make a ride stiffer ride without struts and you have a spongy ride
Old Nov 23, 2004 | 01:05 AM
Cr@zy Squ33
What? If you drive without struts you go nowhere as the car would be sitting on the pavement, your car needs sturts. I may have misread what you wrote but thats exactly what you said.
Old Nov 23, 2004 | 03:41 AM
LowSlowNeon
Like crazy said...if you want a smooth ride, I repeat "DO NOT LOWER YOUR CAR". Your lowered car no matter what strut/spring combo you go with it will always be a rougher ride than stock.
