header Q....
Old Nov 26, 2004 | 11:12 PM
GroundControl's Avatar
GroundControl
Default header Q....
i ordered the pacesetter header sohc for my neon. do i need the Stainless Flex Joint Pipe for it to fit? Does anypne else have a header on there neon?
Old Nov 26, 2004 | 11:51 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: header Q....
No. You do not need it. The header comes with spring bolts.
Old Nov 27, 2004 | 12:11 AM
GroundControl
thanks
Old Nov 27, 2004 | 07:16 AM
71RoadRunner's Avatar
71RoadRunner
I had a Mopar Performance chrome header on my '99 R/T and I loved it.
Old Nov 27, 2004 | 02:50 PM
anti92's Avatar
anti92
The header would make it sound better I'm sure, but does it do much for performance?
Old Nov 28, 2004 | 01:18 AM
elric62285's Avatar
elric62285
Uuuuhhhhhhhhhhh.....YEAH! A header helps speed the exhaust out of the engine by providing a less restrictive path for gasses to flow through. A header is definately a must have.
Old Nov 28, 2004 | 08:50 AM
2K4NeonR/T's Avatar
2K4NeonR/T
Hey guys I'm new to the forum and I have a question about a header for my 04 Neon R/T. I know a header could make a big difference on a stock 04 Neon but would it be worth getting for my R/T? Would the performance increase be worth the money? Thanks for the help, 2K4
Old Nov 28, 2004 | 09:28 AM
casper's Avatar
casper
The header will help with performance. You may lose a little low end depending on what else is done to your car, but the top end should be better and the sound also.
Old Nov 28, 2004 | 01:36 PM
GroundControl
I have a high flow muffler on there now. im putting the header on when it gets here. Should i bother making the pipe from the cat to the muffler bigger? i herd it was a decent size it comes with. If i do put a bigger pipe on wont i loose back pressure? thanks
Old Nov 28, 2004 | 08:48 PM
ryanmills06's Avatar
ryanmills06
how hard it is to install headers. Just ordered ceramic coated pacesetter header for my 2k neon and I was wondering how hard it will be for me so install at home. or if i should shell out money at garage. thanks
