Why you shouldnt run platinum plugs in the neon!
Old Jul 16, 2008 | 08:57 PM
  #101
Exubus's Avatar
Exubus
Default RE: Why you shouldnt run platinum plugs in the neon!
ORIGINAL: mantisman51
Well I guess you told me. Take a look at the Champion platinum plug package and go to their website. I guess they only make them, they don't know a thing about installing them. I was and am referring only to platinum plugs. I would hope anyone with a half a brain or more would gap a copper plug.
I would certainly hope so too... although I have seen people who had no clue what a spark plug even is, so then again I assume nothing when it comes to... well, just about everything lol.
Old Dec 1, 2008 | 12:18 AM
  #102
Kath's Avatar
Kath
platinum is supposed to be 'bad' because of the reverse current 'waste spark' in the neon ignition system. This unduly erodes the platinum coating on the one tip, causing them to wear out much faster than platinum is advertised to last.
nobody should notice any real performance 'drop' though, at least not until such time as you erode that platinum coating away.
however, I tried some platinum +4's when i got my neon because the originals were aging and i really wanted to pamper the car. This was before reading up on the neon + platinum debacle. When i realized I had installed the wrong sort for a neon engine, I figured i'd give them a good 20k miles before pulling them out, thinking they wouldn't degrade overnight. strangely I noticed a decrease in idle quality, low rpm performance, and fuel economy, starting about 2 weeks after installation. When I pulled them out, the platinum wasn't eroded yet, i mean i only had them in for a month. They just really sucked as spark plugs in my neon. I suspect gapping was the issue, they just didn't spark well with any soot on them. Replaced them with iridiums, runs great.
So above and beyond platinum issues, I feel that the +2 and +4 design (whether platinum or not) is just a poor match for a neon. most cars have a larger gap than neons do. gm for example usually runs 45, not 35. that's a visually noticeable difference.
wouldn't gappable single prong spark plugs with platinum on *both* electrodes work fairly well though? I forget the brand, but i've seen those around. or platinums with a solid platinum alloy tip instead of a super thin coating? I mean hypothetically, looking at the science of why platinums degrade so fast in a waste spark system, I don't see why those particular sorts would be problematic.
Old Jan 16, 2009 | 07:33 AM
  #103
gcrn7081's Avatar
gcrn7081
Here is my$.02. I will not add all the tech write ups some have. But more my personal experience. I ran platinum plugs after I bought the neon. It ran so bad, wife came out and thought I messed the car up and was really worried. I took them back, I then bought NGK and the car runs a 100x better.
Old Jan 25, 2009 | 10:00 PM
  #104
Spawne32's Avatar
Spawne32
been running the NGK G-power platinum plugs for 6 months now, no problems what so ever, plugs look like they are brand new
Old Sep 4, 2009 | 09:34 AM
  #105
BlackStar's Avatar
BlackStar
im goin to try the ngks's i've been sticking to champion for the past yrs i never heard ngk's in a american car
Old Sep 24, 2012 | 08:27 PM
  #106
bdaniel230's Avatar
bdaniel230
Originally Posted by SlowAssNeon
that im not sure of. i change my plugs every other oil change, and so far the ngk's have looked better overall imho. but functionally, they both worked about the same.
If you note in the owners manual, you shouldn't have to change the plugs more than every 80K miles. Unless of course, you have figured out a way to put a mechanical distributor in the car.
Old May 12, 2013 | 03:22 PM
  #107
Robert72380's Avatar
Robert72380
In my 01 Neon I ran the bosch platinum 4's it never had any problems and i got around 30-33 mpg per fill up.
Old Sep 14, 2014 | 06:05 PM
  #108
sbhawaiian's Avatar
sbhawaiian
My 2000 neon runs rough at idle especially with the a/c running. when I let the car crawl at idle it jerks in drive or reverse. After reading your posts I pulled out my platinum plugs and replaced them with standard NGKs. The car runs a lot smoother now. I found a little oil in the spark plug tubes so I decided to replace the seals at the same time. I think they may have been the original seals because they were hard as plastic. I like easy fixes.
Old Mar 16, 2015 | 06:38 PM
  #109
MR1960's Avatar
MR1960
Agree'd my$.02 (gcrn7081)
