Cheap Upgrades
Old 05-11-2005, 12:26 AM
XrZ_MsN's Avatar
XrZ_MsN
XrZ_MsN is offline
Default Cheap Upgrades
What are some Cheap Upgrades to do to my 2002 Dodge Neon? I have a cold air intake, Carbon Fiber Exhaust Muffler, Mesh grill, and 2 36" Red Neon lights under the sides.
what could i do the engine to get a few more hp? im guessing i cant have anymore than 140hp because its 132hp stock, and its sitting around 2,600lb.
Old 05-11-2005, 12:38 AM
BDM's Avatar
BDM
BDM is offline
Default RE: Cheap Upgrades
Got any pictures of it?
Old 05-11-2005, 01:08 AM
highrevr/tflea's Avatar
highrevr/tflea
highrevr/tflea is offline
mmm.....next step would be header , intake manifold, ecu, and plugs and wires. the cheapest are plugs and wires so id do that next.
Old 05-11-2005, 02:20 AM
XrZ_MsN's Avatar
XrZ_MsN
XrZ_MsN is offline
No pictures yet, im going to take some soon
how much do those plugs and wires cost?
Old 05-11-2005, 02:59 AM
SlowAssNeon's Avatar
SlowAssNeon
SlowAssNeon is offline
check www.modernperformance.com for prices on different plug wires.. basically pick whichever you like the look/color of, as theyll all perform pretty equally. just stay away from APC and Nology wires really.
plugs, i wouldnt really consider an "upgrade".. theyre more of a maintenance thing than an upgrade. but a set of NGK V-powers should run you about $7 for a set i believe.
some other performance modifications you can do, would be stuff like underdrive pulley, ecu (check www.howellautomotive.com for that one) .. 60mm throttle body.. header.. and cam swap (magnum cam and valve springs isnt too pricey)
Old 05-11-2005, 10:43 PM
lblackneon's Avatar
lblackneon
lblackneon is offline
Plugs and wires wont really do much (especially w/ hp). Your next upgrade should be the header. Pacesetter makes a header around 140 dollars that will do a great job in upgrading the hp.
Old 05-11-2005, 11:46 PM
techmanbd's Avatar
techmanbd
techmanbd is offline
What are peoples views on th OBX headers for the 2nd gens?
Old 05-12-2005, 12:10 AM
XrZ_MsN's Avatar
XrZ_MsN
XrZ_MsN is offline
Heres what my car looks like right now
Old 05-12-2005, 01:58 AM
highrevr/tflea
Airmass to me is better Ive had pace setter and in my opinion its junk and I could buy it for 100 dollars not 140. Airmass high flo is the way to go. And magna flo high flow cat and exhaust.
Old 05-12-2005, 04:03 AM
lblackneon's Avatar
lblackneon
If those were hubcaps is saw, I say upgrade that ASAP.[X(]
Quick Reply: Cheap Upgrades
