Removing the side molding
Old Aug 18, 2005 | 01:52 PM
got boost?'s Avatar
got boost?
Default Removing the side molding
Hey one more thing I was wondering how you can remove the side molding from an SXT?
Thanks
Andy AKA got boost?
Old Aug 18, 2005 | 03:08 PM
casper's Avatar
casper
Default RE: Removing the side molding
It is held on by double stick tape.
Old Aug 18, 2005 | 04:59 PM
got boost?'s Avatar
got boost?
So the fishing line trick will work on it then.
Old Aug 18, 2005 | 05:31 PM
casper's Avatar
casper
ORIGINAL: got boost?
Yep, and some good adhesive remover.
Old Aug 19, 2005 | 01:43 AM
y2neones's Avatar
y2neones
do it on a hot day, it will make it so much easier
Old Aug 19, 2005 | 03:21 AM
casper's Avatar
casper
ORIGINAL: y2neones
Or use a hair dryer or heat gun, but it is summer you should not have a problem.
Old Sep 2, 2006 | 12:46 AM
Pablodragon's Avatar
Pablodragon
Hi!
new here, I have a 04 SE..just aquired about 2 months ago and am slowly getting things done to it....
I wanted also to remove the black side molding on mine... asked some friends and found this post....
I finally just went out today after work and just pulled them off! it was around 70 degrees out...
but they did leave some foam sticky lines.... so now I have a blister on both thumbs from "rolling" off those sticky foam lines![&:]
..just washed the car afterward and now I got smooth sides!
Old Sep 4, 2006 | 11:28 PM
QBall02's Avatar
QBall02
ORIGINAL: Pablodragon
Hi!
You should have left the molding. It matched your awesome spoiler!
