Turbo 4 my neon...
Old Dec 1, 2006 | 12:48 AM
  #91
spudsterier's Avatar
spudsterier
Default RE: Turbo 4 my neon...
well it isnt the spoolboy mod....mine is a little different.....only the return line goes into canister.....i am using the stock feed line out of the tank
Old Dec 1, 2006 | 12:51 AM
  #92
03neonRT's Avatar
03neonRT
Oooh ok...haha now that makes more sense...
Old Dec 1, 2006 | 07:57 PM
  #93
DOHCgarrett t3's Avatar
DOHCgarrett t3
i have a few questions about the fuel pump now,
first of all How the Fu*^ do i install it?? is there a webpage that tells me how? what else do i need alont with how do i install with a FPR?
Old Dec 1, 2006 | 10:00 PM
  #94
spudsterier
if you are talking about the external pump then its easy...i mounted mine to the underside of the spare tire well.....ran a hose from the stock pump to the external pump....then from the external pump to the fuel line that runs up to the engine compartment....
install of a fpr is easy....you need some AN 90 degree fittings, a return line, fuel injector hose, and hose clamps....i mounter my regulator to the fender well where the A/C canister was at....ran a fuel line from the fitting on the front of the fuel rail to the regulator, then from the regulator to the steel return line....
i highly recommend getting a haynes manual so you have a good idea of locatons
here are some pics of the regulator, return line, external fuel pump, and engine bay
[IMG]local://upfiles/29901/CAF1FAB8608C44C49B7FE7276F66459E.jpg[/IMG]
[IMG]local://upfiles/29901/C217AE8550674E5292F4BC07755B2B0D.jpg[/IMG]
[IMG]local://upfiles/29901/CC2DC9A190BC4D3AAFD991E08F8AE54E.jpg[/IMG]
[IMG]local://upfiles/29901/6332AFCA281247A190C0E32F0A939586.jpg[/IMG]
Old Dec 2, 2006 | 04:52 AM
  #95
DOHCgarrett t3
okay I think i got it.
seems easy enough i have a manual at home i dot know if its hayned or chilitons either way thanks for the help i cant wait to get to work on my car only 10 more months left in iraq . . . fu$*
Old Dec 2, 2006 | 05:45 PM
  #96
das2123's Avatar
das2123
ORIGINAL: DOHCgarrett t3
Keep safe and I know I appreciate what our Armed Services are doing for our Country [sm=americanasmiley.gif][sm=patriot.gif]
Old Dec 3, 2006 | 05:37 AM
  #97
DOHCgarrett t3
thank you for your support when i get home ill have a new baby too "Riley Eden" i cant wait im so excited
Old Dec 8, 2006 | 08:37 PM
  #98
DOHCgarrett t3
is the magnum intake for the 2nd gen neons?
Old Dec 8, 2006 | 10:19 PM
  #99
das2123's Avatar
das2123
It came on the 2nd gen R/T's and ACR's. It will work on the 1st gen's but takes some work.
Old Dec 13, 2006 | 12:26 PM
  #100
DOHCgarrett t3
will it work on a DOCH? and what does it take if so
