Turbo 4 my neon...
Old Nov 26, 2006 | 08:08 PM
  #71
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Turbo 4 my neon...
testing signature
Old Nov 26, 2006 | 08:15 PM
  #72
DOHCgarrett t3
testing signature
Old Nov 27, 2006 | 12:12 AM
  #73
spudsterier's Avatar
spudsterier
i havent seen any pods the completely replace the piller...just the ones that partially overlay it..(thats what i got from ebay for 19.00)
the oil ending unit is located on the back of the block by the tranny..if you look from underneath the car then the sensor should have a green clip and there should be a cross brace that goes from the tranny to the block...the sensor is right next to the brace
here is the only pic that i have of my gauge pod
[IMG]local://upfiles/29901/298C2DC603094043A019EE167D5A9FE2.jpg[/IMG]
Old Nov 27, 2006 | 08:36 AM
  #74
sneaky's Avatar
sneaky
ORIGINAL: AirWolf
No no no I am not going to give you your crappy way and post pics of my hahn turbo 96 must not read any drag racing magazines or road and track or car and driver there are lots of articles about the hahn turbo kit in a automatic 1st gen neon faster than a srt4 . Ive had a srt4(acr) and have 2 neons now and you devils reject only have a stratus so how would you know about any srt4s . Imports like the sti are better made than most american cars. Stis are better in alot of ways to a srt4. Just tired of dodges time for a real import beast. Now theres 3 trouble makers and Im a gal and a little older than you guys. Ive had my 96 for 10 years now so I know a bit more than you about turbo neons. My 2004 sxt has alot of engine mods plus nitrous.
Blah...blah...blah. I had a turbo from Hahnracecraft for my old '95 neon. I don't know what you're talking about it being a 1st gen and all. If you're talking a Stage 1 turbo kit running 10-11 seconds I'm calling B.S. on you also. The stage 1 turbo kit from hahnracecraft was putting out around 230-250hp to the crank. You would need their stage 4 or 5 kit to be running those times. So please...SHHH!!!
Old Nov 28, 2006 | 07:23 PM
  #75
das2123's Avatar
das2123
ORIGINAL: sneaky
ORIGINAL: AirWolf
LOL....they quit this debate some time ago if you look at when they were posted.
Old Nov 29, 2006 | 01:47 AM
  #76
spudsterier
yeah the topic slightly changed since then.....and now he messed it all up[>:]
Old Nov 29, 2006 | 09:34 PM
  #77
AirWolf's Avatar
AirWolf
I never said my 96 was a 11 second ride maybe a 12 like hahn said and mines a stage 2 turbo kit.Shes being redone meaning custom painted and 17inch rims and tires and drop , kitted, cuda hood, and alot more. I havent actually had her out this year shes being worked on by my husband and me . Also my sxt is just being built for shows and cruizin around no turbo nitrous is in my 96 now. I have nothing against any turbo or supercharged ride love all of them!
Old Nov 29, 2006 | 10:46 PM
  #78
fullbuilt's Avatar
fullbuilt
this was hallarious. garret your sending is on the back of the block closer to the driver side. just to play along your both right thats what boost controllers are for. back when i was on stock internals with a couple bolt ons. my turbo had me doing a 13.4 however i blow up that motor after awile and its a five speed. how much boost your car can handle depends on the turbo. an srt turbo will be safe around 8lbs the 20g around 12lbs and larger turbos the internals can handle more. it all depends on your spool dump. and wolf you have to understand that without pics people woulnt believe you. i have pics of my motor just so i dont go throw the same thing. garret if you need help i got a garret too.
Old Nov 30, 2006 | 04:53 AM
  #79
Dare_2_Dodge's Avatar
Dare_2_Dodge
I added a cold air to mine--short ram air. It gives me alittle more torque though it isnt noticeable till i get to the drag strip.
Other than the cold air, there are no mods to the 02 neon sxt. It runs 14s...
Tires help i think, i got 205/60s on stock 15s. Plus I like to remove some excess weight before i race, like take the subs out of the trunk, the passenger seat, and whatever else i had laying in there that was not difficult to remove, then put back really quick and drive home.
Still, stock neon sxts are not half bad. It WILL beat a grand prix V6. It WILL beat a tacoma SR5, it WILL beat a 66 mustang running a straight six two barrel carb (my room mate's... he broke the drive shaft just from goosing at a dead stop...)
Old Nov 30, 2006 | 09:27 AM
  #80
DOHCgarrett t3
Thanks fullbuilt,
I apreciate it. I cant do it now but when i get home i might just scrap the neon I have and get a 2 Door but the engine i have in there i know is good cause i got the car new back in 2001 with 19,519 miles on it and i since then have took good care of it (engine anyways)
Heres what im planing to do with it though
Garrett T3 turbo- have it
60 mm MPx throttle bodies - need it
Walboro High Flow Fuel Pump -have it
Accel fuel injectors.. 30lbs/hr - need them
Moroso Aluminum Racing Oil Pan- need it
INDY Intake Manifold - need it
Front Mount Intercooler - have it
JE 8.8:1 Turbo Pistons .020 Over bore - need it
Finaly Eagle H beam connecting rods - need it
and balancing of the crank shaft - i dont know if ill do that though
is there anything else i can do? Or use or not use???
