dodge neon car audio help !!!!
Old Apr 16, 2006 | 04:37 PM
dan_kohan's Avatar
dan_kohan
Default dodge neon car audio help !!!!
basically i have a 1200 watt amp with 2 phoenix gold 10 inch subs and i had it all wired up and had the subs pounding, then i took them out caus ei had to do some work on the box i biuild, then when i put the system back in it woudlnt work. so i used a volt meter to see if i was getting power to the amp. The amp light still turns on so there is power there. I c heck the power wire terminal and the light go's on.....but when i test the terminals for the speakers on the amp there is no power going to them. what the hell is going on ! and i dont have a fuse on the amp and the fuse under the hood is fine. i have no idea what the hell is going on here.
Old Apr 16, 2006 | 06:01 PM
highline95jl's Avatar
highline95jl
Default RE: dodge neon car audio help !!!!
[sm=icon_rtfm.gif]
Old Apr 16, 2006 | 11:27 PM
Bassboy's Avatar
Bassboy
PM Sent.
Old Jan 11, 2007 | 03:10 AM
mcfisher666's Avatar
mcfisher666
what name brand amp do u have and how many channels is it. 2 or 4? cuz it sound to me that something on the inside of the amp conected to the speaker terminalshave gone bad. i had the same problm with my 2200 watt percision power amp. i would suggest putting another amp in to test the problem and if the new one works then thats ur problem
Old Jan 14, 2007 | 07:12 AM
Kapitald's Avatar
Kapitald
check if you have any settings that would mute the subs...like if the amp has a master/slave switch then make sure it is on master....if all your connections are good and settings are good...something is wrong with the amp bro....
Old Jan 14, 2007 | 01:41 PM
spudsterier's Avatar
spudsterier
maybe you blew some mosfets...
do you have a sub setting on you head unit...
just a thought
Old Jan 18, 2007 | 03:32 AM
djmagic's Avatar
djmagic
Make sure your wires are connected to the right areas
Old Jan 28, 2007 | 09:46 PM
iamamp3pimp's Avatar
iamamp3pimp
sounds like the amp is blown.
since you have a meetr, test for AC voltage at the speaker outputs on the amp, or just plug in the RCA's
Old Mar 29, 2007 | 09:40 PM
Psurichie's Avatar
Psurichie
Check the remote wire from the head unit. I had problems with that in ever car i have ever owned.
