Stupid Battery Light!!!!
Old Jun 11, 2004 | 04:15 PM
GreenReaper93's Avatar
GreenReaper93
Default Stupid Battery Light!!!!
Hello everyone! New here so please be gentle. My wife's '95 Neon keeps getting the battery light on. I've changed practically eerything (Alternator, fuseable link, battery) and it still keeps staying on. I'm starting to catch heat from my loudmouth Father-in-Law that I'm not taking care of my wife, so I'm begging anyone to help me so I can get her mobile and him off my back. Thanks in advance!
GR 93
Old Jun 11, 2004 | 04:52 PM
moparturd's Avatar
moparturd
Default RE: Stupid Battery Light!!!!
I would check all the connections, including the grounding straps. If the battery terminals are loose,that can cause the light to come on.
Old Jun 11, 2004 | 06:37 PM
GreenReaper93
Thanks, I'll look at that when the weather breaks!
Old Jun 12, 2004 | 09:58 AM
71RoadRunner's Avatar
71RoadRunner
Have you checked it for codes yet? The cheap way would be to remove the light bulb behind it.[sm=smiley36.gif] If it doesn't show any other problems, try disconnecting the battery for a while and reconnect it and see if it persists.
Old Jun 12, 2004 | 12:04 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: 71RoadRunner
Now that sounds like something I would do!!!![sm=smiley20.gif][sm=smiley36.gif]
Old Jun 12, 2004 | 07:14 PM
NYG's Avatar
NYG
Definately check the codes - my 96 Neon is goofy at times - my light came on and it was for a Thermal Battery Warning - apparently some Neon have a temperature sensor under neath the battery. Mine does not have the sensor but I get a warning light occasionally
Greg
Old Jun 14, 2004 | 07:28 PM
GreenReaper93
Thanks for the responses guys! I haven't had a chance to get under it and look at the wiring, etc. due to weather. I'll get the codes and post 'em up asap. Thanks again!
Old Jun 26, 2004 | 03:36 PM
GreenReaper93
Hey everyone! Thanks to all that replied. Checking the trouble codes I came up with code 41. The book says that there's an open or short circuit in the generator field. I'm guessing a grounding strap/connector???? Let me know what you think. Thanks!
Old Jun 26, 2004 | 04:12 PM
b_s_d's Avatar
b_s_d
Could be a flaky ASD (auto shut down) relay. It's located in the underhood power distribution center.
Old Jun 26, 2004 | 11:01 PM
GreenReaper93
Already changed it. This really has me stumped. I'm about to the point of taking roadrunner's advice. Help!!!!!!
