Starter Relay
Old Dec 2, 2006 | 03:12 AM
neon chic's Avatar
neon chic
Default Starter Relay
I've had my '00 neon since february and so far have gone thru 3 starter relays anyone know y?
Old Dec 3, 2006 | 02:20 AM
winsettz's Avatar
winsettz
Default RE: Starter Relay
I wonder if it's still under warranty. Sounds like an electrical issue?
Old Dec 4, 2006 | 01:57 AM
neon chic's Avatar
neon chic
No its not it was bought used from an automax without warranty
Old Dec 5, 2006 | 12:08 AM
das2123's Avatar
das2123
Starter not grounded properly??? What about the fuse?
Old Dec 5, 2006 | 02:21 AM
neon chic's Avatar
neon chic
the relay itself is the only problem i've had it make a clicking noise when i turn the car off that i'm told is from the relay if that helps... its not under warranty so should i takeit to the dodge dealer down here or would it be the same to just take it to a mechanic? will the dealer charge to look at it since its not under warranty?
Old Dec 5, 2006 | 11:36 AM
das2123's Avatar
das2123
I would NOT take it to the dealer. Take it to a mechanic you trust and know, if you can. Ask some people if they know a mechanic they trust.
Old Dec 5, 2006 | 03:44 PM
Freerider's Avatar
Freerider
ORIGINAL: neon chic
simple answer.... the dealership will overcharge for anything and everything. Something they do. They will make you pay to bring it in and get it looked over.
Go the way das said. It is cheaper and they will work on it properly.
Old Dec 5, 2006 | 05:02 PM
neon chic's Avatar
neon chic
thnx guys! i figured they would charge way too much they want$88 per hour the only problem is its really hard to find a good mechanic down here but thank you!!
Old Dec 5, 2006 | 05:44 PM
fullbuilt's Avatar
fullbuilt
if you have to take it somewhere, take it to a corporate garage. dealers charge to much for parts and privet owned are known for fixing whats not broke.
Old Dec 6, 2006 | 01:53 AM
neon chic's Avatar
neon chic
we dont have any corporate garages here its all dealers and private owned
