rockers chatter
Old Mar 31, 2007 | 06:29 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default rockers chatter
probably been posted on before....
are ya supposed to hear the rockers chatter every time you let off the accelerator?
should i just adjust em a bit?
Old Mar 31, 2007 | 11:09 PM
Ralph78's Avatar
Ralph78
Default RE: rockers chatter
Is it rocker lash or just "Diesel" noise?
It sure would be a good idea to check them if you are concerned.
Ralph
Old Apr 1, 2007 | 01:34 AM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Ralph78
Ralph
explain rocker lash.
perty much. when I let off the accelerator pedal, you hear the chatter from the engine. I can rev it up a bit, let off and it sings it chattery song.
Old Apr 1, 2007 | 02:03 PM
jakebrake's Avatar
jakebrake
by your mileage, i would definatly check your valve lash. I believe it is .010 intake and .020 exhaust. When checking it check for the rockers to be pitted or the valve bridges. If they have been running loose there is a good chance a few will need replaced.
Old Apr 1, 2007 | 04:27 PM
Kev_n_AZ's Avatar
Kev_n_AZ
guessin Ill pick up 6 valve cover gaskets....and dig out my feeler guages.
thanks for the info.
Old May 1, 2007 | 05:00 PM
Kev_n_AZ's Avatar
Kev_n_AZ
well I dropped the $100 to have the valves adjusted.
watched an learned too!
no need for the tdc pin at all or any special tools!!
a ratchet on the alt pulley and turn the engine BACKWARDS slowly.....watching the valves open and close. then start at cyl's 1 and 2 and work your way around.
the rockers still chatter, but in unisen now!
idles better and accelerates smoother......
just gotta get the kickdown adjusted on the trans....[:@]
Old May 1, 2007 | 05:20 PM
Drew's Avatar
Drew
guess you'll be a pro at it now eh???
Old May 2, 2007 | 12:30 AM
jakebrake's Avatar
jakebrake
After about 500x, you'll get the hang of it.
Old May 2, 2007 | 04:05 AM
Kev_n_AZ's Avatar
Kev_n_AZ
I may be learning the expensive way, but at least its not all guess work!
Old May 2, 2007 | 10:12 AM
Drew's Avatar
Drew
you might have. . .but remember, sometimes you have to pay for education.
