juice hot unlock code
Old Apr 6, 2007 | 12:08 AM
trix77's Avatar
trix77
Default juice hot unlock code
Is it worth $100.00. After paying out the a** for this thing you would think signing the release form would be good enough. Has anyone tried the 6th level code, and is it worth it?
By the way, everyone that has a Ram like mine put diffrent chips in and they all smoke. I get nothing. Any reason why?
Old Apr 6, 2007 | 12:12 AM
sharx ram's Avatar
sharx ram
Default RE: juice hot unlock code
How many miles do you have on it? Mine didnt smoke too bad for awhile, then it picked up
Old Apr 6, 2007 | 12:20 AM
trix77's Avatar
trix77
It's a 99 with 150,000 on it. And I mean nothing not even a poff of smoke ever.
Old Apr 6, 2007 | 12:31 AM
rbmason's Avatar
rbmason
That's good to hear, cause I have a 99 with about that many miles and am looking to get the Juice.
How hard is it to install
Old Apr 6, 2007 | 12:39 AM
trix77's Avatar
trix77
I looked worse than it was. But I screwed up when it told me how to avoid getting air in the fuel lines. Read it over well. I started it right after the install and it sputtered and died. It took about 30 small engine cranks and allot of air bleeding to get it running. But the 1/8" NPT Tap was hard to find. Make sure you get one before you start. I took me a couple of hours but now that I look back I wonder why. I just was being very particular on how clean I made it look. I love it but I am pis*ed that this Hot Code is going to cost me anouther $100.00. If they have the info for the programmer you should get it. I understand the release but not the extra $$.
Old Apr 6, 2007 | 05:49 PM
R0oster31's Avatar
R0oster31
It doesn't smoke at all? Hmm, do you have fuel pressure and does it seem like it is doing anything?
Old Apr 7, 2007 | 01:41 PM
trix77's Avatar
trix77
Runs much better than before I put the juice in, but no smoke. Fuel presure stays right around 12-15 psi. Has anyone purchased the hot unlock code?
Old Apr 7, 2007 | 03:38 PM
R0oster31's Avatar
R0oster31
I was going to, until the edge/attitude didn't seem to do anything. I ran all the diagnostics and it is connected properly and the box is working, so maybe my MAP sensor is shot...
Old Apr 8, 2007 | 11:41 AM
trix77's Avatar
trix77
yea, something must be wrong. I am not 100% in love with my juice but I can't say that it did not make a diffrence. It definatly is a whole diffrent truck with it in. Did you try thier tech line?
Old Apr 8, 2007 | 12:57 PM
cumminalong's Avatar
cumminalong
If that Juice is working correctly, your truck should be a rocket. Mine will damn pull your arms out on level 3 or higher, especially in T/H mode. When that TC locks up in 3rd..............holy crap, it's like getting kicked in the **** by a mule.
I had some fun w/ 2 PSD's last night. I looked in my mirror, saw cab and mirror lights and said, "This should be fun."
I turned off the back light on the Attitude (stealth mode, baby!) and waited for them to come on up. I let them pass, as they were moving pretty good, and saw no gauges or anything. Then.............bye bye sucka!
After I got done messing around, I realized I missed my exit..................2 exits back. [:-]
