Front Drive Shaft Lube ????
Old Apr 24, 2007 | 02:29 PM
Buckwheat's Avatar
Buckwheat
Default Front Drive Shaft Lube ????
Do all 2006 4X4 2500 CTD's have a female type greese hole on the front drive shaft? I jacked the front driver's tire off the ground last night and had my son turn it. I could not find the fitting. If my truck has one is it on the front or the back part of the drive shaft. I looked for it for quite a while with no luck.
Old Apr 24, 2007 | 03:06 PM
DBLR's Avatar
DBLR
Default RE: Front Drive Shaft Lube ????
Go and read this URL to find the lube point photo's : https://dodgeforum.com/m_487238/tm.htm
Old Apr 24, 2007 | 04:15 PM
Buckwheat's Avatar
Buckwheat
Thanks, I new there was an old thread but I cound'nt find it. So it is on the transfer case end of the shaft? I still am not convinced my truck has a greasable one?
Old Apr 24, 2007 | 04:18 PM
steve05ram360's Avatar
steve05ram360
I will add it to the Dodge CTD info thread so it's easier to find. if there are any other threads that should be added let me know...
Old Apr 24, 2007 | 05:18 PM
Drew's Avatar
Drew
it should already be in there.
Old Apr 24, 2007 | 05:56 PM
steve05ram360
I didnt see it so I added it to the top post as #9
Old Apr 24, 2007 | 06:09 PM
Drew's Avatar
Drew
4th link. . .2nd post. https://dodgeforum.com/m_578941/tm.htm
I guess we prolly need to make a tech thread with all the links in it. would also be a good thread to list the best sites to order repair, go fast, and suspension parts.
Old Apr 24, 2007 | 07:52 PM
steve05ram360
oops, my bad. I should have looked further down. We can fix the thread any way we see fit, both of us have access to every post.
Old Apr 24, 2007 | 09:46 PM
MikesCTD's Avatar
MikesCTD
I read in this post https://dodgeforum.com/m_578941/tm.htm that the grease fitting is only on 2005 & up. Does this also include the 2004.5? Since they changed engines at half year!
