Drivetrain shaking
Old Apr 29, 2007 | 09:50 PM
Silverline's Avatar
Silverline
Default Drivetrain shaking
Ok, this one is on a '96 3/4 ton extended cab CTD. We've been having problems with the drivetrain shaking like a fool, especially when towing a gooseneck trailer. I just finished replacing two if the three u joints ( I ran out of O2 on the torch) and things got better. But later today it started happening again. I intend to change the last u joint, but was wondering if anyone had anything like this happen before. About the only other thing I can think of is the carrier bearing in the drive line itself. Thanks.
Old Apr 29, 2007 | 10:54 PM
dixiedodge7369's Avatar
dixiedodge7369
Default RE: Drivetrain shaking
on my dodge challenger i had a really bad vibration at like 80 mph then i changed to 3.91 rear gears and it would vibrate at 55 60 mph replaced u joint no help. balenced the drive shaft no help the bearing in the tail shaft that supports the slip yoke was worn and it would cause a vibration i could move the slip yoke up and down and it was very loose.... not the same vehicle but a possible solution????
Old Apr 29, 2007 | 11:00 PM
THE153624's Avatar
THE153624
I had the carrier bearing go out on my '98. It was vibrating extremely bad and was very noticeable what the failure was, the rubber around the bearing came apart. Make sure your U joints are in-line, if not, it will vibrate.....
Old Apr 29, 2007 | 11:04 PM
Silverline's Avatar
Silverline
That's what we were thinking. I just wanted to check to see if anyone else ever had any similar trouble before I started tearing into the entire drivetrain from the tranny back. Guess I'll change the carrier bearing when I change the last u joint. Thanks for the input.
Old Apr 29, 2007 | 11:09 PM
jakebrake's Avatar
jakebrake
When you do the carrier bearing, make sure you put the yoke back on in time with the d line.
Old Apr 29, 2007 | 11:18 PM
Silverline's Avatar
Silverline
Does anyone know of a part supplier that carriers the bearing kits for the yoke?? I've been looking and can't find anything that seems right.
Old Apr 29, 2007 | 11:23 PM
NickBeek's Avatar
NickBeek
Have you checked all the tires. I had a come and go problem in my wifes old Plymouth minivan, when I took it in they put it on the lift and found a big bubble in the tire. Funny thing was you couldn't see it while weight was on it. Just a thought.
Old Apr 29, 2007 | 11:27 PM
jakebrake's Avatar
jakebrake
Either a driveline shop, or napa should have one. If you got an extra soul laying around you can get one from the dealer
Old Apr 29, 2007 | 11:28 PM
Silverline's Avatar
Silverline
Tires are fine. End just ended up putting new rear tires on to see if that was the problem. And the ones on the front are fine too. Basically its been a slowly developing problem for awhile now.
Old Apr 30, 2007 | 12:06 AM
THE153624's Avatar
THE153624
I got the part from Dealer and took it to local driveline shop to press it on....
