droping a cummins in a 95
Old May 2, 2007 | 03:02 AM
crash dummy's Avatar
crash dummy
Default droping a cummins in a 95
hey, Hopefuly u guys will be more helpful then people at work they just tell me it won't work and that i'm retarded. i've got a 95 ram 1500 the motor and trannys bout to give in and ive got the truck the way i want it(the looks atleast) so id like to keep it. i seen the pimp my ride were they put a duramax in a impala and the thought of puting a cummins in my 1500 won't leave my head. is it posiable if so what would it take? what would b beter 4 it the 12v or 24v what yearand so on thx 4 any info
Old May 2, 2007 | 04:34 AM
CutterW's Avatar
CutterW
Default RE: droping a cummins in a 95
Wieght is a big factor. Other than that the others will answer for ya
Old May 2, 2007 | 05:22 AM
JotiGrains's Avatar
JotiGrains
It's possible. I saw on Trucks, some guy droppeed a 24V in a 70's Dodge 250.
Old May 2, 2007 | 10:21 AM
Drew's Avatar
Drew
a guy near where I live had a nicely built 12v dropped into his 06 1500 RC SB.
is it possable. . .YUP. . .would the thing run like a scalded cat on crack. . . .YUP
Old May 2, 2007 | 02:58 PM
crash dummy
what all would i have to have to make it posiable. would it better to get a demolished truck that the motor and drivetrain is good? that way i'd have everything. the truck isn't a daily driver so theres no time limit i was wanting to put bigger turbo, injectors, intercooler, intake, fass, etc b4 i even get it driveable
Old May 2, 2007 | 03:13 PM
Silverline's Avatar
Silverline
I'd saystart with the wrecked truck if you can. Everything will be there and you can just pull the parts off.It'll make life easier since you won't be chasing parts down from place to place. You might also check and see if there'sinfo somewhere on the internet for someone that's done the swap before. I'd almost bet that there is somewhere.
Old May 2, 2007 | 03:33 PM
tdmopar59's Avatar
tdmopar59
i think the biggest PIA would be redoing the wiring...
Old May 2, 2007 | 03:41 PM
BFR's Avatar
BFR
i think the 2 biggest factors are going to be weight and computers if u plan to go with a 24v. if it where me i would go with a 12 vavle just for complexity issues. and i would go with a 94-97 model year they had the p-7100 injection pumps that have just about no fueling limits the fastest drag trucks still havent hit the limit with these pumps.
Old May 2, 2007 | 04:00 PM
crash dummy
sounds like a plan. i'm glad there people i can talk to about stuff with out geting called a Dumb@$$. Thx for all the info. also as far as weight. i kno i'll probly beef up the frame a lil but should i take the coils and stuff off the wrecked 2500 to take care of the extra weight?
Old May 2, 2007 | 04:49 PM
Batphreak's Avatar
Batphreak
Plan on beefing up that frame more than just a little. The big C weighs about twice what the little gasser you're taking out does. Don't forget that the entire rest of the driveline is going to have to be upgraded too, at least a 47RE/H tranny (a beefed up 727 could handle it too, but no overdrive built in), D70 out back, D60 up front. 1500s are independent front 'spension, the D60 is going to be a stick axle.
