motor oil as fuel
Old May 2, 2007 | 09:19 PM
joepascoe19's Avatar
joepascoe19
Default motor oil as fuel
i was looking arround on the net and i found sevral people burning there used motor oil in there trucks most of them were filtering it b4 they put it in the truck i was wondering if u could do it on th newer trucks?
Old May 2, 2007 | 10:35 PM
Drew's Avatar
Drew
Default RE: motor oil as fuel
I wouldnt try it. . .the detergents will mess up the injection system something bad
Old May 2, 2007 | 10:48 PM
NickBeek's Avatar
NickBeek
I used to work with a guy (an old german guy) he had an old VW rabbit diesel, which he called "Roger". Anyhoo, he would burn anything in that thing, used hydraulic oil, used engine oil, used cutting oil. I mean just about any indutrial waste he could pour in it. Now this was his beater car and he didn't care if he killed it. But that thing would run on just about anything, it would hickup and fart and smoke but run.
For my $40K truck it is only clean #2 diesel.
Old May 2, 2007 | 11:14 PM
UpBranchLiner's Avatar
UpBranchLiner
Ive heard of trucking company (fleet of Petes)using used oil as a fuel mix, there drivers said it worked well,(smoked a little but looked cool)
Old May 2, 2007 | 11:15 PM
JotiGrains's Avatar
JotiGrains
No, don't do it in the newer trucks. The 24V have too much electronics. My '05 guide says not to burn anything more than 5% biodiesel. My friend, who we make biodiesel togther, burns 100%, but he's got like a 95 12V, he knows a guy who burnt 30% in his '02 and it barley started once, the second time it didn't start at all.
Old May 3, 2007 | 12:43 AM
Drew's Avatar
Drew
you can burn B100 no problem. . .you just have to change the fuel filter alot when you start useing it. after a few tanks all will be well with bio.
the main reason for useing oil is to lubricate the injectors and the pump. this exact thing goes on in Iraq. the only fuel out there is JP8, a very 'dry' fuel. the aqddition of ND30 to the fuel keeps the pumps happy.
Old May 3, 2007 | 03:06 AM
Silverline's Avatar
Silverline
Used motor oil sounds like a fast road to a gummed up and nasty fuel system. With our oil being black as night already I'd really hate to run it through as fuel and put all those detergents, soot, carbon and god knows what else through the pumps and injectors. That, and if you're burning straight oil you better be running a oil change shop to keep yourself in supply.
Old May 3, 2007 | 06:04 AM
joepascoe19
ya that was what i was thinking on the new ones being so electronic
but i might try it out on my ford mud truck it would be better then paying to despose of it
Old May 3, 2007 | 12:08 PM
Charles Darwin's Avatar
Charles Darwin
Soot is one of the best grinding compounds ever. I wouldn't use old oil.
