Problems Already
Old Jun 11, 2007 | 11:27 PM
  #21
Drew's Avatar
Drew
Default RE: Problems Already
there shouldnt be a speed limit on the regen. . .as long as you are running within the engines power band(above 1600rpm) it should run the regen.
Old Jun 11, 2007 | 11:32 PM
  #22
bksram3500's Avatar
bksram3500
maybe ill just have someone else to drive it for me every once in a while. the mechanic told me it was the first regen I dont know why it wouldn't do it with me driving
Old Jun 11, 2007 | 11:35 PM
  #23
NickBeek's Avatar
NickBeek
Be thankful you don't have the new Ford, that thing will light off while sitting in a parking lot. I'm not referring to the flame thrower model either. When that thing wants a regen, it will raise the idle and do it's thing. The only problem there is it will melt or burn anything within 3 feet of the exhausttip while doing so. That is why they have that goofy looking exhaust tip, they are trying to induce some cool air into the exhaust so that it won't burn up the next car in the parking lot.
Old Jun 11, 2007 | 11:38 PM
  #24
Drew's Avatar
Drew
lol. . .ball park franks plump when you cook'em
Old Jun 11, 2007 | 11:42 PM
  #25
bksram3500's Avatar
bksram3500
My owner manual says not to park on dry grass, leaves, or anything flammable.
Old Jun 12, 2007 | 12:20 AM
  #26
Drew's Avatar
Drew
wow. . .so basicaly one of these guys can start a forest fire when it goes through regen.
Old Jun 12, 2007 | 01:12 AM
  #27
jakebrake's Avatar
jakebrake
If your running in the power band, you shouldn't have to do a "manual" regen. The temps should be hot enough to burn off the soot. If that isn't enough, you can either load it down with a trailer, or run down a gear. Other than that it will build up soot and require a regen.
Old Jun 12, 2007 | 01:16 AM
  #28
Watermelon's Avatar
Watermelon
Sorry to hear about your problems with the new ride.Just to kinda help out, RUN that truck like your mad at it and it will probably serve you better. These things werent made to lug around town at low rpm's. Keep it wound up and drive the crap out of it!!! My 04 has a 100k on it and believe me, it hasnt had many easy days. You gotta remember you have a 100k warranty to play with. USE IT!! and enjoy.
Old Jun 12, 2007 | 01:34 AM
  #29
bksram3500's Avatar
bksram3500
Thanks for the help. I will be pulling a trailer this week for about 800miles so I will let you know how the 6.7 pulls
