oil gauge needle, kinda dumb ?, but gota ask
Old Jun 14, 2007 | 02:45 AM
moconst's Avatar
moconst
Default oil gauge needle, kinda dumb ?, but gota ask
On my stock oil gauge in the dash, Ive notice lately that it moves alot when I accelerate. Is it normal for it to go higher as I speed up? and then lower when I speed down?
Never noticed it before the mods, so im not sure if it moved prior.
Thanks
Old Jun 14, 2007 | 02:46 AM
speakle's Avatar
speakle
Default RE: oil gauge needle, kinda dumb ?, but gota ask
That is typical, as the engine goes faster so does the oil pump increasing pressure.
Old Jun 14, 2007 | 02:47 AM
jakebrake's Avatar
jakebrake
Oil pressure will rise with engine rpm. Oil pressure will also be higher when the oil is cold.
Old Jun 14, 2007 | 02:53 AM
moconst's Avatar
moconst
ok, wasnt sure. cause i never really paid attention to it before
Old Jun 14, 2007 | 04:08 AM
Mayfair's Avatar
Mayfair
Don't EVER be shy about asking a question here !! That's how we ALL learn.
( especially me ... )
Old Jun 14, 2007 | 10:10 AM
Drew's Avatar
Drew
actualy. . .that gage can be trusted about as much as a pedophile running a day care center.
theres a transducer coming off the oil pump that as long as it sees 5psi, your good, and the 40 psi you see at normal RPM's and it going up and down is only controlled by the computer and what it may think the actual oil pressure is.
Old Jun 14, 2007 | 10:31 PM
jakebrake's Avatar
jakebrake
completely forgot about that, thanks drew. On the older engines they ran a sending unit. You can't buy that sending unit anymore. They have updated it to an oil pressure switch which means that you have to reprogram the ecm on the older engines.
Old Jun 15, 2007 | 12:35 AM
s15996b's Avatar
s15996b
thats right, until the latest software release the reading was a "perception" of what the ECM wanted you to see!
