what is high idle feature?
RE: what is high idle feature?
ORIGINAL: savage.basher
.......some of the questions I ask probably make it sound like I don't even own a diesel[sm=confused06.gif].
BTW, the dealers are pretty much unaware of this option and once they figure it out they usually want to charge you for it. I got mine for free, by going in for some pay work (oil change) then going back to the shop and asking the tech to hook up the starscan tool and we found it and enabled it. If you can do this it is in the same place where they can enable day time running lights and a few other options. Good luck.
High idle, Day Time Running Lights, and Accessory Delay are the ones I know about. I like the HI and AD options alot. With the AD you can turn the key off and the radio, windows, and cig lighter will stay working for the time limit set when they enableit (up to 10 minutes)or until you open the door. I don't know what else can be done for sure.
Trending Topics
ORIGINAL: NickBeek
On mine the acc delay is allready enabled. I also really like that feature.
