Autometer A-pillar and gauges install w / PICS !!
Old Jul 30, 2007 | 08:25 PM
  #31
finny's Avatar
finny
Default RE: Autometer A-pillar and gauges install w / PICS !!
originally drew
I used the ciggy outlet for mine since it is a switched source.
he thats smart cuz ill never use it.
Old Jul 31, 2007 | 01:24 AM
  #32
Mayfair's Avatar
Mayfair
ORIGINAL: finny
i dont know were totap the gauges into for power. did you hook up too like dash lights or stereo or wut. any info would help thanks.
I tapped into the cig outlet for the main power, and a parking light wire for the lights. The lights in the gauges don't dim when i dim the dash lights, but really .... how often do you dim the dash lights. No biggie to me. I was just happy to find a light wire !!
Old Jul 31, 2007 | 12:44 PM
  #33
finny's Avatar
finny
i think when i do it i am gunna use this
http://www.bd-power.com/ram/product....Pod&tt=ram
because i am going to alsobe running a low fuel pressure warning light as well as gauges.
Old Jul 31, 2007 | 01:24 PM
  #34
Mayfair's Avatar
Mayfair
BD Diesel Performance Power Pod Kit - Auxiliary Power Distribution
Item is available.
$99.99 (all prices in USD)
WOW that's a LOT of money for what it is I think. Can't say that I blame you for trying to make your wireing easier, that just sounds expensive. Doesn't Geno's sell a painless kit for 1/2 that number?
Old Jul 31, 2007 | 01:31 PM
  #35
finny's Avatar
finny
they might ill check
Old Jul 31, 2007 | 01:37 PM
  #36
finny's Avatar
finny
http://www.genosgarage.com/prodinfo....r=FUSE%20BLOCK
is this it. if it is its alot cheaper!
Old Jul 31, 2007 | 02:00 PM
  #37
kg1687's Avatar
kg1687
Nice job. Now I have to get my gauges. Yay!!!
Old Jul 31, 2007 | 02:14 PM
  #38
finny's Avatar
finny
because mayfair did fuel preasure and not tranny temp i am just wondering were the sensors go. a guy i was talking to said i have to cut the coolent line and put the sensor in there or somthing like that.
Old Jul 31, 2007 | 02:17 PM
  #39
Mayfair's Avatar
Mayfair
This is the one that I was talking about, but that one that you linked may work as well. I just don't know how it works if you'll haveswitched and unswitched or what.
Here's the one ...
PAINLESS WIRING KIT - 4 HOT/3 CONSTANT
function ShowlargeImage(whatimage)
popupWin = window.open(whatimage, ', 'scrollbars,resizable,width=500,height=450');
Item Number :PPP-70107-PAINLESS
Unit Price: $51.95
Quantity
Refer this page to a friend
Detailed Description
No doubt about it, you’re going to add accessories to your Turbo Diesel. As a solution to those unorganized, haphazard accessory wiring situations, add a Painless Wiring auxiliary fuse block.
Painless Wiring Kit - Cirkit Boss Auxiliary Fuse Block - 4 Ignition Hot/3 Constant Hot
Old Jan 2, 2008 | 12:32 PM
  #40
chet's Avatar
chet
how much did you have to cut off the sides of the stock pillar to get it to fit i just got mine and it is WAYYY off like your was and i plan on cutting the speaker out ? and how do you make sure you got it lined up so they will click back in ?
