Tranny flush
Old Jul 11, 2007 | 12:23 PM
VA Vince's Avatar
VA Vince
Default Tranny flush
When should I flush my trans. Its a 06 with 31k. 2500 if that matters.
Old Jul 11, 2007 | 01:11 PM
Drew's Avatar
Drew
Default RE: Tranny flush
dont worry about a flush. . .just empty the fluid in the pan, change the filters, re-fil and drive on.
Old Jul 11, 2007 | 01:40 PM
Joel_MD's Avatar
Joel_MD
When you say "flush," that usually means bringing it to a shop that uses a machine that plumbs into the cooling lines to replace the ATF, without replacing the transmission filter or even dropping the pan. It's easier and less messy for the mechanic, but many would argue that it's a bad idea. Read what Amsoil says about transmission flushes.
Now, it is a good idea to do an old-school transmission service (new filter and gasket, refill with fresh ATF) and then "flush" the torque converter and cooling lines with fresh fluid, since they hold a lot of the ATF.
Old Jul 11, 2007 | 01:54 PM
JimmyDiablo's Avatar
JimmyDiablo
How do you flush the torque converter. Also what about the bands on the tranny, how do you adjust those?
Old Jul 11, 2007 | 04:11 PM
Drew's Avatar
Drew
to flush the entire system you will need about 5 gallons of fluid.
remove the tranny cooler line FROM the cooler and let hang into a 5 gallon bucket. crank the engine and place transmission in neutral then begin to slowly pour the new fluid down the dipstick at the same rate it is comeing from the cooler line.
when the fluid turns bright red stop engine and hook line back to tranny. top tranny off and your good.
this process is expensive since you need about 5 gallons of ATF to do it. you are just better off dumping what is in the pan, changing the filters, and adding new back.
to adjust the bands there is an adjustment outside the trans, and one inside. I am not sure of thier exact location.
Old Jul 11, 2007 | 04:41 PM
JimmyDiablo
ORIGINAL: Drew
Thanks Drew. I know the flush will be expensive for fluid alone. but when would you recomend it interval wise.
Old Jul 11, 2007 | 04:55 PM
Drew's Avatar
Drew
around every 30K depending on use.
if you tow heavy you may get around 15-20K of service, however most of us dont tow alot so 30K is good.
Old Jul 11, 2007 | 09:54 PM
dhvaughan's Avatar
dhvaughan
i think you'd be a lot better off installing a remote filter and a drain plug in the transmission. about every 1-2 yr (or 12-24k) just drain the pan (using the handy-dandy plug) and replace the handy-dandy external filter. no muss no fuss. then occasionally drop the pan and change the internal filter. atf+4 is expensive at about $5/qt, and you'll waste a lot trying to do a flush.
Old Jul 12, 2007 | 10:37 AM
DBLR's Avatar
DBLR
FYI,
It is not a good idea to install an in line filter on a Dodge transmission as they will cause a drop in line pressure and cause more problems then they are worth. BTW, This info has been passed on to me by several re-builders who have over 25 years of working on transmissions and who have seen them used on Dodge transmissions over the years.
Old Jul 16, 2007 | 10:07 AM
VA Vince's Avatar
VA Vince
I should of stated change instead of flush. I need to change the oil in 2k miles so I figured I would change the tranny oil. Just figured with 31k on it, now would be a good time to change.
Drew- you said in your post to flush every 30k??? Just want to make sure.
Thanks
