before i buy...
Old Jul 16, 2007 | 03:10 PM
miknwv's Avatar
miknwv
Default before i buy...
im thinkin about buyin a used 2000 to 2002 2500 cummins diesel truck...most of the trucks im lookin at have 150K or better miles on them. anything i need to watch out for? what are some possible things that would already be wrong or about to go wrong on these trucks?
Old Jul 16, 2007 | 05:00 PM
rbmchief's Avatar
rbmchief
Default RE: before i buy...
watch out for the lift pump. the easiest way is to cycle the key on/off without starting the truck, on the third on cycle leave th e key on and watch the odometer for code. if there are no codes it will say p done. theres a list of codes here just do a search for p codes. if you find a truck to purchase, the first thing your gonna wanna do is get a fuel pressure guage on it. low fuel pressures take out the expensive injection pump (vp44) on thses year of trucks. 99-02.
Old Jul 16, 2007 | 05:26 PM
Mayfair's Avatar
Mayfair
I don't think the code cycling thing works on 2nd gens
Old Jul 16, 2007 | 06:09 PM
miknwv's Avatar
miknwv
yeah ive gotten codes off of my 2001 gasser like that with the key cycling...should be the same for a diesel.
Old Jul 16, 2007 | 07:25 PM
Drew's Avatar
Drew
the key trick works on 01 and up trucks. . .I think. on the 3rd gens you can get the hour meter as well. . .on 2nd gens you have to hook the computer up to an OBD scanner.
Old Jul 16, 2007 | 08:07 PM
jakebrake's Avatar
jakebrake
my 02 will do it with the key cycle. Also ceck for the 53 block. Theres a thread in the faq/diy up at the top.
Old Jul 16, 2007 | 08:12 PM
miknwv's Avatar
miknwv
sweet, thanks. what about ball joints? ive heard a bit about those going bad, but at what mileage do they normally peter out?
Old Jul 16, 2007 | 08:13 PM
nickcoletti's Avatar
nickcoletti
it worked on my truck, and it showed all dash's.... i supose that would mean a good day!
Old Jul 16, 2007 | 09:12 PM
Drew's Avatar
Drew
yea. . .if theres nothing to report it will just show all dashes and then it will say 'done'
