edge jammer injector nozzels
Old 07-22-2007, 10:57 PM
YAMAHARIDER5's Avatar
YAMAHARIDER5
YAMAHARIDER5 is offline
Default edge jammer injector nozzels
Ok i bought a set of edge jammer injectors nozzels and i went to my service manuel and it said i needed two tools to remove the injectors so i went to dodge and they let me borrow the tools. so my question is how do you remove the nozzel off the injector and are their any special tools needed to do this?
Old 07-22-2007, 11:36 PM
GFB's Avatar
GFB
GFB is offline
Default RE: edge jammer injector nozzels
Do yourself a favor and take those nozzles to a diesel injection shop to have them installed and pop tested and shimmed.
Old 07-23-2007, 12:26 AM
jakebrake's Avatar
jakebrake
jakebrake is offline
Too much of a pain to do it yourself. As said above, take them to a shop and have them done. You'll thank yourself in the end
Old 03-06-2008, 10:25 AM
YAMAHARIDER5
what would be a good shop to take it too i live in morganton nc about an hour from charlotte is their anyware close to me that can do this.
Old 03-06-2008, 12:25 PM
nickcoletti's Avatar
nickcoletti
nickcoletti is offline
(not trying to change the subject) i asked a little while ago about injectors and would it be expensive to have them put in. everyone told me its EASY to do yourself and there is a DYI on doing them and now i read you guys are saying its hard[sm=confused06.gif]
i was curious because i can shop for injectors online, but i cant for labor prices..... whats the ballpark that one would look for to get them installed??
Old 03-06-2008, 01:51 PM
Drew's Avatar
Drew
Drew is offline
whole sticks are not the problem. . .it is when you change nozzels you need to have the injector pop tested to make sure it is popping at the proper pressures.
3rd gens are a bit different since the injectors are electronicaly controlled, however there is the possability of shimming that may need to be done.
Old 03-06-2008, 02:07 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
So changing the whole stick is basically just unscrewing the old one, and screwing in the new one?
Old 03-06-2008, 02:40 PM
Drew's Avatar
Drew
Drew is offline
well. . .not realy unscrewing it, just pulling it out. it is heald in by bolts.
Old 03-06-2008, 06:26 PM
jt2271's Avatar
jt2271
jt2271 is offline
keep us posted on how much of a difference they make... im thinking about a set this summer.. but wanna make sure they make a diff. and is it better to buy the whole stick or just nozle... nozle is much cheaper from what i see... is there any benifit aside from easy install on going with whole stick.... J [sm=dontgetit.gif]
Old 03-06-2008, 08:56 PM
woligator's Avatar
woligator
woligator is offline
i didnt tested mine,just unscrew them,there is a nut on the end so u can remove tham be carefull there is 2 pieces in it...
ill change them later to full bodied...
pop testing them can cost as much as full bodied so no saving there
but my truck run stronger whit them so so far im happy
and yeah there is a copper washer that slide on the tip of the injector DONT LOOSE THEM and when putting them back put a dab of greas to make sure they hold
else run like crap and dont start after
Quick Reply: edge jammer injector nozzels
