rough idle/white smoke
Old Jul 23, 2007 | 10:35 AM
red dually's Avatar
red dually
Default rough idle/white smoke
changed fuel filter/still does it on start up,too much cetane booster?
Old Jul 23, 2007 | 11:21 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: rough idle/white smoke
white"exhaust" usually depicts a water leak, right?
blue is oil burning off.
Old Jul 23, 2007 | 11:53 AM
jakebrake's Avatar
jakebrake
Depends on what the exhaust smells like. White smoke can either be coolant or fuel. Have you tried pulling the edge?
Old Jul 23, 2007 | 12:07 PM
CowboyBob's Avatar
CowboyBob
White smoke can also mean the engine is running lean. Check your lift pump.
Old Jul 23, 2007 | 12:18 PM
Drew's Avatar
Drew
white smoke. . .not enough fuel. . .black smoke. . .too much fuel. . .blue smoke. . .oil.
Old Jul 23, 2007 | 03:39 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: CowboyBob
now I was abruptly informed by a person that if you do not have enough fuel to a diesel engine, it will not run. you can not have a "lean" mixture since there is no carb or throttle body.
I told him that he was full of it.....
what yall think?
Old Jul 23, 2007 | 05:26 PM
firemansdodge's Avatar
firemansdodge
ORIGINAL: bajafun
ORIGINAL: CowboyBob
what yall think?
Can't run a diesel lean. The only time you run "rich" (no such thing on a diesel) is you dump alot of fuel until your turbo spools up. Usually if you have a programmer/tuner on. The white smoke could be an injector and blue is oil burning. Could be alot of scenarios out there. Take it to a mechancic or if under warranty take to a dealer to check out.
Old Jul 23, 2007 | 06:19 PM
Drew's Avatar
Drew
you can run a diesel "lean" as in not enough fuel. . .most of the time the engine will just die
Old Jul 23, 2007 | 08:40 PM
NCcummins's Avatar
NCcummins
does it mean anything if my 02 that is straight piped blows a little bit of black smoke on start up and take off? or completely normal?
