Pyrometer?
#23
RE: Pyrometer?
ORIGINAL: Drew
300F is a good safe temp to shut down. . .you can run hard at any temp, just dont go over 1200pre turbo on your 02.
Just trying to soak up as much knowledge before my trip as possible.
#24
RE: Pyrometer?
ORIGINAL: jakebrake
Is that what I think it is? a water cooled turbo[:-]
Mayfair when soot is burned it turns to ash just like your charcoal in your barbeque does. Ash builds up in the dpf and eventually the dpf will need pulled off and cleaned
#25
RE: Pyrometer?
ORIGINAL: hildenja
Yes, my turbo apparently has a water jacket around it.
ORIGINAL: jakebrake
[IMG]local://upfiles/56817/F6D82F8D7B7846EE9E5D4A520A8C508B.jpg[/IMG]
#27
RE: Pyrometer?
ORIGINAL: V8 Cummins Diesel
What is the duribility of bank's juice with attitude? How long does the attitude last? Will it last as long as a regular guage?
#29
RE: Pyrometer?
I thought forums are for learning! That is all I'm doing! Nothing wrong with that! I am learning from scratch!
Bottom line: when you modify ANY engine you have to watch particular parameters to prevent ruining the engine, especially if you are running it to the edge(towing, racing, or just punching it all the time...)
I don't see anything wrong with asking questions, but make sure you can't find the answer somewhere easily, in searching you may find the answer to questions you never knew you had! That is the best way to go for a newbie in any engine.
#30
