Pyrometer?
Old 07-30-2007, 08:49 AM
V8 Cummins Diesel's Avatar
V8 Cummins Diesel
V8 Cummins Diesel is offline
Default Pyrometer?
Will adding a pyrometer and guage able me to detect the regeneration process in the 6.7L?
Old 07-30-2007, 10:21 AM
Joel_MD's Avatar
Joel_MD
Joel_MD is offline
Default RE: Pyrometer?
Yes, when mine is regenerating the EGT is higher than normal. At highway speed on a straight and level stretch, instead of the normal 700-850 degrees it will be 900-1050 during regen.
Old 07-30-2007, 03:12 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
What exactly IS "regen mode"?
I've heard it mentioned a couple of times now and I'm not sire if I get it. Does the truck raise the temp of the exhaust somehow to burn off some soot or something every once in a while?
How ??
Old 07-30-2007, 03:18 PM
Drew's Avatar
Drew
Drew is offline
ORIGINAL: Mayfair
How ??
you pretty much got it. . .the DPF collects the soot that is created from the combustion of diesel. after a while the injectors will fire again at some point in the combustion process to raise temps so this carbon in the DPF will be burned off.
Old 07-30-2007, 03:56 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
ORIGINAL: Drew
And what ... be released as SOOT ???
I don't get it ... why bother? Isn't there any way of eliminating this annoying stupid POS ??
Old 07-30-2007, 04:26 PM
Drew's Avatar
Drew
Drew is offline
well. . .think of it like charcoal. . .the soot that is being collected is just carbon, like charcoal. . .you would think it wouldnt hold a flame but it does, same thing with the DPF, it will burn the carbon into CO2.
Old 07-30-2007, 05:01 PM
V8 Cummins Diesel
Where is the best place to put pyro sensor?
Old 07-30-2007, 05:43 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
I installed mine after the turbo, however some folks here like to install it in the manifold so that they can see exactly what the temps are comming from the motor. I installed it after the turbo because I wanted to know when it was ok to shut down after towing.
Old 07-30-2007, 06:28 PM
kg1687's Avatar
kg1687
kg1687 is offline
Wow mayfair that's smart. Thanks for the idea
Old 07-30-2007, 07:22 PM
Drew's Avatar
Drew
Drew is offline
both have their positives. pre turbo lets you see the EGT's comeing out of the cylinders and you can tell real quick if your about to burn up the turbo. post turbo lets you see what the turbo is seeing.
Quick Reply: Pyrometer?
