BullyDog "V 2.4.1" Help
Old Jul 30, 2007 | 09:20 PM
htgriffith's Avatar
htgriffith
Default BullyDog "V 2.4.1" Help
CHANGES
V2.4.0 July 20, 2007
Dodge - Added Tire Size to recalibrate OEM Speedometer ’03- ‘07 Dodge Cummins. (I have 265/70/17. What do I need to put as far as inch's, Its raining outside and have not had a chance to measure)
- Added P.T.O. function to idle truck up to 2000 RPM –’03-’07 Dodge Cummins. (Not a clue, I did select idle up, It would not let me do anything under this selection)
- Added Speed Limiter Adjustment from 50 MPH to 200 MPH ‘ ’03-’07 Dodge Cummins (Got this one ok)
- Added all light features for ‘07 Dodge Cummins. (Do not need, I have a 06)
- Added Daytime Running Light Enable/Disable for ‘06 & ‘07 Dodge Cummins. (I enable this, Nothing happen, Do I need to do somthing on the truck?)
- Included TSB # 18-022-07 for ’03-’05 Dodge Cummins.
Thanks if you have one and can help me out...........................
Old Jul 30, 2007 | 09:23 PM
timesublime's Avatar
timesublime
Default RE: BullyDog "V 2.4.1" Help
The standard idle up is 1100-1500, so that makes a higher high idle.
Old Jul 30, 2007 | 09:49 PM
htgriffith's Avatar
htgriffith
Thanks, Do you no how to get the lights to work? I pushed enable, Then tryed it two times, even turned the truck off on ect.
Old Jul 30, 2007 | 10:56 PM
htgriffith's Avatar
htgriffith
AHHHH,Ok ready for a good laugh? The day time driving lights work better if you have it in gear! Duuuuuuu..............
Old Jul 31, 2007 | 12:46 AM
Tommygunz's Avatar
Tommygunz
you noticing any discernable fuel mileage gains?
Old Jul 31, 2007 | 10:49 AM
KillerCummins's Avatar
KillerCummins
When you talk about the bullydog update, is that with the triple dog or the master programmer thing? Because I have the trip/outlook combo and use the little outlook screen to view my true speed with my 37's. I hate not using my factory speedometer. I hope you're talking about the triple dog. Thanks
Old Aug 4, 2007 | 12:05 AM
htgriffith's Avatar
htgriffith
Yes it is for the Triple Dog. As far as MPG I get 2-3 MPG increase with the program. I get 3.5 - 4.5 if I keep my foot out of it. I just cant.........
Old Aug 4, 2007 | 11:29 AM
KillerCummins
Hells ya, I can't wait to try it, I was about to order one of those superlift tru-speed recalibrators. If this works, you will have made my day. Thanks a lot
Old Aug 4, 2007 | 03:03 PM
htgriffith's Avatar
htgriffith
This is a list I copyed for you to see all the up grades they have made.
Triple Dog
Triple Dog Power Pup Version Info
GM
- Improved Key-On sensing 01-07 Duramax
Ford - Added Part # VXFB0XX.hex
V2.3.9 Apr, 2007
Added new part number for GM EGR reflash
V2.3.8 Feb, 2007
1. Added 2007 Part numbers Back into Triple Dog
45325753AE
45325751AF
45325733AE
45325731AF
45325853AE
45325833AE
2. Added new read calibration routine for 2006 and 2007 Dodge.
3. TSB for 2006 and 2007 Dodge for Transmission Shift and Battery
Charging Enhancements.
V2.3.7 Feb, 2007 4532575.1AE Removed from Downloader
4533575.3AD Removed from Downloader 4533573.1AE Removed from Downloader 4533573.3AD Removed from Downloader
4533583.3AD Removed from Downloader
4533585.3AD Removed from Downloader
2007 Cummins 5.9L TSB’s and Special Functions Disabled.
3532555.3AS 2006 5.9L TSB Retuned and Added to Downloader
3532555.3AS 2006 5.9L TSB Recoded
353XXX.XXS 2006 5.9L TSB’s Compressed/Encrypted to Downloader .
V2.3.6 Test Version, Not and Official Release
V2.3.5 Jan, 2007
5.9L TSB’s Now Available
V2.3.4 Oct, 2006
New TSB’s Available on Dodge
V2.3.3 Oct, 2006
Customer Downloader
Dodge 2007 Dodge Release
All Agent Access for Triple Dog
V2.3.2 Aug, 2006
Customer Downloader
GM 2007 Duramax Release
Master Downloader
All Agent Access for Master Triple Dog
V2.2.7 Mar, 2006
Customer Downloader
Ford New Part Number VXAP1xxHEX 2003 Superduty
Dodge Vehicle Calibration Read Fix
Vehicle Boot Protection
GM Improved Tuning
Master Downloader
Ford New Part Number VXAP1xx.Hex 2003 Superduty
GM Improved Tuning
V2.2.5a Feb, 2006
Customer Downloader
Ford New Part Number VXDB1xx.HEX 2005 Excursion
Fixed Multiple Vehicle Part Lock
Dodge New Flash 253253X.XAE 2005
New Flash 203252X.XAI 2004
Resolved Erasing of Key Cycles, and Fuel Used
Recalibrated 2004.5-2005.5 Vehicles
New Feature 2005 Vehicle Options Available!
: Idle Up Enable
: Auto Door Lock/Unlock Enable
: Set Headlamp Delay Time
: Horn Chirp on Lock Enable
: Optical Chirp on Lock Enable
: Unlock Driver Door on First Press Enable
All Improved Upgrade Procedure
Master Downloader
V2.2.3 Dec, 2005
Customer Downloader
Dodge 2003 - 2005 Vehicle Options Available!
: Idle Up Enable
V2.2.2 Nov 23, 2005
Customer Downloader
Ford Changed Text upon Vehicle Selection
Bully Dog Technologies • www.bullydog.com • 866-bullydog (866-285-5936)
Dodge 2006 Dodge Triple Dog Available
2006 Dodge Crazy Larry Tune Available
New Feature 2006 Vehicle Options Available!
: Idle Up Enable
: Fog Lamp W/ High Beam Enable
: Seatbelt Minder Chime Disable
: Accessory Delay Time
V2.2.1 Nov 9, 2005
Customer Downloader
Duramax LLY Timing Modification
Ford New Part Number VXCF1xx.HEX 2005/2006 SuperDuty
New Part Number VXCF4xx.HEX 2005/2006 SuperDuty
New Part Number VXBC9xx.HEX 2004 SuperDuty
New Part Number VXAL2xx.HEX 2003 SuperDuty
Dodge Idle Up Feature Activated
All Improved Bootloader/Upload Applications
V2.2.0 Nov 6, 2005
Master Downloader
V2.1.0 Aug 31, 2005
Master Downloader
Duramax New Part Number 15193885 2005 Duramax Improved Download Efficiency
Ford New Part Number VXCF1xx.HEX 2005/2006 Superduty
New Part Number VXBC7xx.HEX 2004 SuperDuty
New Part Number VXAM6xx.HEX 2003 SuperDuty
New Part Number VXAM0xx.HEX 2003 SuperDuty
New 2003 Ford Speed Limiter Calibration
V2.0.4 Sep 15, 2005
Customer Downloader
Duramax Crazy Larry Now Available for Free Download
New Part Number 15097100 2001 Duramax
Ford VXCF0N4.HEX Transmission Upgrade
Dodge VIN Lock Error Message Fix
V2.0.3 Aug 29, 2005
Customer Downloader
Recover Mode for Debug
Dodge Crazy Larry Now Available for Free Download
All Improved Configuration for Bootloading
V2.0.2 Aug 7, 2005
Customer Downloader
Duramax New Part Number 15188873 2001 Duramax
Ford Improved Download Efficiency
Dodge Improved Download Efficiency
Master Downloader
V2.0.1 Original Tuning.
Customer Downloader – All Ford, Dodge, GM Vehicles
Master Downloader – All Ford, Dodge, GM Vehicles
Old Aug 4, 2007 | 03:04 PM
htgriffith's Avatar
htgriffith
This is a list I copyed for you to see the upgrades they are always making
Triple Dog
GM
V2.3.9 Apr, 2007
V2.3.8 Feb, 2007
45325753AE
45325751AF
45325733AE
45325731AF
45325853AE
45325833AE
V2.3.5 Jan, 2007
V2.3.4 Oct, 2006
V2.3.3 Oct, 2006
Customer Downloader
V2.3.2 Aug, 2006
Customer Downloader
Master Downloader
V2.2.7 Mar, 2006
Customer Downloader
GM Improved Tuning
Master Downloader
GM Improved Tuning
V2.2.5a Feb, 2006
Customer Downloader
: Idle Up Enable
Master Downloader
V2.2.3 Dec, 2005
Customer Downloader
: Idle Up Enable
V2.2.2 Nov 23, 2005
Customer Downloader
: Idle Up Enable
V2.2.1 Nov 9, 2005
Customer Downloader
V2.2.0 Nov 6, 2005
Master Downloader
V2.1.0 Aug 31, 2005
Master Downloader
V2.0.4 Sep 15, 2005
Customer Downloader
V2.0.3 Aug 29, 2005
Customer Downloader
V2.0.2 Aug 7, 2005
Customer Downloader
Master Downloader
