B+W Gooseneck Ball Hitch Question
RE: B+W Gooseneck Ball Hitch Question
The general rule of thumb is to have the ball about 2" in front of the axle. The farther back you get the more you put weight on the rear of the truck instead of the axle and suspension. I've seen people put their own in and end up with the truck looking like it was hauling a heavy bumper pull instead of a gooseneck.
does anybody have a BW gooseneckhitch in thier 07 3500 ?? does it clamp to the frame, I only have one hole in my frame and I know that ain't enough to supporta hitch, they claim that the hitch just bolts right on, I am trying to find out HOW it mounts, has anybody PERSONALLY installed thier hitch in a 07 3500?? how the hell are they mounted???
ORIGINAL: BLACKPearl06
The B&W actually sits on the frame and then bolts to it's self. Then the hole you see keeps the hitch from moving side to side. There will be some cutiing in the bed but nothing needs to be cut or drilled on the frame.
ORIGINAL: alpinDave
did yours only have one hole as well ??
The B&W actually sits on the frame and then bolts to it's self. Then the hole you see keeps the hitch from moving side to side. There will be some cutiing in the bed but nothing needs to be cut or drilled on the frame. THANX!! That is the answer I am looking fer!!!!
