A/C compressor clutch won't kick on
Old Aug 11, 2007 | 11:43 AM
57ringo's Avatar
57ringo
Default A/C compressor clutch won't kick on
Drove my 05 dodge QC CTD this morning for the first time and the A/C worked fine and after about 15 miles it just blows hot air. I checked the clutch and it's not turning. The fuse and relay are ok. Is there any moreother than in the fuse block? Does anyone have a wiring diagram so I can check if it's getting power to the clutch? Is there a high and low pressure switch on these? This was lightly wrecked when I got it so I thought maybe I have a connection problem to look for but everything looks ok as far as I can see.
Old Aug 11, 2007 | 05:28 PM
MCDiver's Avatar
MCDiver
Default RE: A/C compressor clutch won't kick on
There is a low pressure switch that will not allow the clutch to kick in if the coolant is too low. I am not sure about the high pressure switch, but think there may be one of those as well.
Old Aug 11, 2007 | 06:23 PM
57ringo's Avatar
57ringo
It seemed to cool too good to be low on freon. I haven't jumped the low pressure switch to see if that's what stopped it from cycling.
Old Aug 12, 2007 | 03:47 PM
57ringo's Avatar
57ringo
I found the high pressure switch but not the low side. Any ideas? I followed the line but didn't see any.
Old Aug 12, 2007 | 05:25 PM
57ringo's Avatar
57ringo
after checking closer, the #16 fuse was blown. I replaced it and just as soon as I turned the a/c back on it blows thew fuse again. Any ideas now?
Old Aug 12, 2007 | 07:48 PM
04CTD's Avatar
04CTD
find out where number 16 goes and look for a short to the body somewhere along the way
Old Aug 12, 2007 | 08:30 PM
dodgerules86's Avatar
dodgerules86
Heres a wiring diagram.
Connector "C130" looks like its located by the firewall, in the middle. "C112" is located by the water-in-fuel sensor.
[IMG]local://upfiles/948/57F86EFB10C64B9B85F605FADAAEBF26.jpg[/IMG]
Old Aug 12, 2007 | 08:40 PM
Drew's Avatar
Drew
I'd say look for shorts or a rubbed harness.
another thing I would look for would be wires that are rubbing the metal lines going to and from the compressor.
Old Aug 15, 2007 | 09:44 AM
57ringo's Avatar
57ringo
I unplugged the connector atthe compressor and put a test light on the wires to make a circuit and turned it on and the test light lights and the fuse does not blow. Just as soon as I plug it into the compressor, the fuse blows. The dealer shop mechanic said it's the clutch coil shorting out. How much of a job is this to change?
Old Sep 1, 2007 | 11:19 AM
57ringo's Avatar
57ringo
It was the coil shorting out....put another one in and it works again.
