Transmission Slipping?
Old Sep 24, 2007 | 03:00 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: Transmission Slipping?
over tightening it will not allow the trans to shift. it will stick in the lowest gear possible. i did that to mine once. couldnt get out of first gear in a block..engine revved and had to shut it down.
sears has the in/lb torque wrench you want. buy it, us it, cklean it, return it (if you have to). they are about $85..well ok, they used to be less than $100....
http://www.sears.com/shc/s/p_10153_1...orque+Wrenches
Old Sep 24, 2007 | 03:06 PM
Erock509's Avatar
Erock509
ORIGINAL: bajafun
Ok thnx, b/c everywhere else i called didnt have anything but 1/2 inch and too big. Ill try sears
Old Sep 24, 2007 | 03:12 PM
Kev_n_AZ's Avatar
Kev_n_AZ
you may need and extension andu jointto make any wrench work.
http://www.sears.com/shc/s/p_10153_1...niversal+joint
Old Sep 24, 2007 | 04:20 PM
Erock509's Avatar
Erock509
Finally done with it, not too bad with the right tools. First time torqueing with guesstimate, way to tight, wouldnt shift outa second. Didnt go to sears but went ace real quik and they had a wrench that went as low as 5ft lbs, so jst went 6 to=72 in lbs. Then loosened as instucted and truck drove fine and as far as i can tell no more slipping. Ill gitty up a lil bit tonight just to check. Thank you all for your help. This place rocks!!!
Old Sep 24, 2007 | 04:28 PM
steve05ram360's Avatar
steve05ram360
cool, glad to hear it' fixed... I would have suggested Home Depot for the torque wrench... I got one from them that did inch lbs... works great from what I can tell...
Old Sep 24, 2007 | 08:46 PM
Erock509's Avatar
Erock509
The problem is fixed so far, I got on it a bunch to test it out and no slipping at all. Lets see if it last. Thnx again
