vacation w/ my CTD
ORIGINAL: roadking096
I see two muffler like appliances down there. Is one a resonator? converter? Will the aero replace both? Thanks again.
You have a 98.5 and you have a 53 block? I didn't think the 53's came out till later.
Two other things that i didn't see on your list. Clean / replace your air filter, and clean your battery terminals and ground wire connections. Faulty grounds have led to erratic shifting.
Have you changed your diff fluids yet?
I confirmed the 53 block after I read about it here. I got a K-N insert filter. I know most guys here don't like em. I'll attend to cables. I already found a loose ground by the bumper bracket, drivers side. Thanks for the muffler info. That was exactly what I wanted to know. I'm gonna do the diffs. Does this year require the friction modifier in my limited slip?
