vacation w/ my CTD
Old 09-26-2007, 09:16 PM
roadking096's Avatar
roadking096
roadking096 is offline
Default vacation w/ my CTD
I took a week off to be with my new truck. I'm planning to change all fluids, replace radiator (leaks), adjust valves, rebuild vac pump, replace front seal, and adjust bands. Is there anything else I need to check/ adjust/ replace while I'm in there? it has 120k on the clock. Thanks in advance for any help.
Old 09-26-2007, 09:35 PM
Drew's Avatar
Drew
Drew is offline
Default RE: vacation w/ my CTD
check the lift pump for proper pressure and if it hasnt been done lately change out the fuel filter.
Old 09-26-2007, 09:40 PM
roadking096
Filter is new. How do I check the lift pump?
Old 09-26-2007, 09:49 PM
Drew's Avatar
Drew
Drew is offline
a pressure gage will do the trick. . .or you can order yourself a pressure gage to mount.
I say this since the early 24 valves (read: those equipped with the VP44 injector pump) will die if the fuel pressure is not maintained. such as the pump dieing the VP44 will overheat and commit suicide.
Old 09-26-2007, 09:53 PM
roadking096
Good advice. where do I tap and what PSI is normal/ minimum?
Old 09-26-2007, 10:03 PM
Drew's Avatar
Drew
Drew is offline
best place to tap would bebetween the fuel filter and the VP44 injector pump. this will also act as a restriction gage and give you a better indication of when it is time to change the fuel filter.
idle you should see around 12-14+ psi. . .normal cruise anywhere from 6-10psi depending on load. full throttle should not go below 4 psi.
Old 09-26-2007, 10:18 PM
roadking096
Thanks.I have the dreaded 53 block, so I'm cautious about upgrades. What would be a good exhaust setup if I don't plan on going over 300hp with mods? Thanks again.
Old 09-27-2007, 06:57 AM
Drew's Avatar
Drew
Drew is offline
many here are very happy with dumping their muffler and putting in an Aero turbine.
Old 09-27-2007, 06:26 PM
roadking096
I see two muffler like appliances down there. Is one a resonator? converter? Will the aero replace both? Thanks again.
Old 09-27-2007, 06:59 PM
NCcummins's Avatar
NCcummins
NCcummins is offline
damn? not below 4? i saw 3 today and put it back down to 1 cuz it scared the crap out of me..
Quick Reply: vacation w/ my CTD
