lift pump
Old Oct 1, 2007 | 06:44 PM
tonyslaramie's Avatar
tonyslaramie
Default RE: lift pump
I wish you luck, as well as NC... what are you going to use for a standpipe at the fuel tank?
Old Oct 1, 2007 | 06:49 PM
NCcummins's Avatar
NCcummins
45 PSI for a fuel pressure? isnt that SUPER high? I know the fass will run around 15 all the time. But I have never heard of 45 psi in fuel pressure?
I just ran outside because the UPS man just came, and of course it was a big white box that said DPP with hte FASS inside, cant wait to start it tomarrow after school!
wish you luck with the fuel system u just got..
-Chris
Old Oct 1, 2007 | 06:59 PM
jakebrake's Avatar
jakebrake
Have fun NC, just like christmas
Old Oct 1, 2007 | 07:38 PM
NCcummins's Avatar
NCcummins
haha i know its just like it...with a HUGE credit car bill!
will take pics and show and tell tomarrow...
Old Oct 1, 2007 | 07:46 PM
blondeguy08's Avatar
blondeguy08
whats the diff. between a FASS system and a regular stock replacement lift pump besides the price? I mean is the fass worth the extra 400-500 $ whats so special about them as to a regular lift pump and stock fuel filter?
Old Oct 1, 2007 | 07:48 PM
NCcummins's Avatar
NCcummins
The FASS has alot more thne just the stock system. It has filters that are larger and last a lot longer, it has a water separator, and puts out more PSI for fuel pressure. Thats all that I know of, but I have only heard good things and im sure someone like Jakebrake could tell you more!
Old Oct 1, 2007 | 07:49 PM
Drew's Avatar
Drew
ORIGINAL: macdiesel5spd
just purchased a frame mounted fuel pump from napa for 80.00. specs out at 45psi. it is for a 91 f-150 5.0L. wish me luck, i hope this works.
probably not since diesel is heavier and thicker than gas. . .may last a few months then die.
also the VP44 is more suseptable to the lift pump going out. . .the CP3 wont die if the pressures go down.
NCcummins's Avatar
NCcummins
http://www.dieselpp.com/
read that...it is self explanitory...
Old Oct 1, 2007 | 07:50 PM
blondeguy08
well..its just really i dont have that much to spend on a lift pump..... lol...... maybe if it was heated..... I run biodiesel sometimes so ya...
Old Oct 1, 2007 | 07:52 PM
NCcummins's Avatar
NCcummins
im pretty sure the system I got has the heater, the dealer from FASS said it did..
