lift pump
Old Oct 1, 2007 | 01:31 AM
macdiesel5spd's Avatar
macdiesel5spd
Default lift pump
what is the cheapest upgrade on a lift pump? i just purchased an 01 2500. upon review of the service records, i found the lift pump failed twice and shelled the injection pump with it. i am scared. can i just install any frame mounted generic electric pump? purchase of the truck has sucked my account dry. any suggestions are apreciated.
Old Oct 1, 2007 | 08:02 AM
CowboyBob's Avatar
CowboyBob
Default RE: lift pump
Any pump that will produce enough PSI (10-15)will work. The Walbro and FASS units seem to be the most popular, but will cost a few $$$ more. But, when you have a $2000 injector pump on the line, the extra $$$$ is worth it.
Old Oct 1, 2007 | 12:55 PM
tonyslaramie's Avatar
tonyslaramie
Is the walbro installed in series with the factory lift pump?
Old Oct 1, 2007 | 01:35 PM
jakebrake's Avatar
jakebrake
No, you bypass the factory lift pump.
Old Oct 1, 2007 | 01:38 PM
tonyslaramie
Would you condemn the factory lift pump, or use them together? Would you install a hobbs low pressure switch or the like to switch pumps in the event of low fuel pressure?
Old Oct 1, 2007 | 01:40 PM
jakebrake's Avatar
jakebrake
The stock lift pumps are junk, aren't even worth dealing with. I would just run the aftermarket one and put a fuel gauge in (or atleast a low pressure light)
Old Oct 1, 2007 | 01:46 PM
tonyslaramie
So the long and short of all this would be remove the in-tank pump, install an in-line walbro and a lowfuel pressuregauge and buzzer. Do we know the micron of the factory/fleetguard fuel filter and is it considered sufficiant if it's maintained as it should be?
Old Oct 1, 2007 | 02:57 PM
SkyboltAl's Avatar
SkyboltAl
Bottom line is: If the truck starts bucking like hell and you suspect the transfer pump just went out, STOP IMMEDIATELY and shut it down or you will trash your injector pump. My bill was $4500 at the dealer. A tow truck ride to the shop is much cheaper.
Old Oct 1, 2007 | 03:00 PM
NCcummins's Avatar
NCcummins
my hold right at 11 psi when idle..but when i mash on it, it drops right to 2, and cna get it to 0 but do not want to...thats why when ever UPS gets here sometimes soon that I have been WAITING FOR ALL DAY with my FASS "150" series 95 pump I am going to install it asap tonight! I got it from www.kensperformancesolutions.com where mayfair directed me too in Cali. He shipped me everything for $635.55 which is right at retail and he paid shipping!
ill let you know how the installs goes and what psi it hols at tomarrow!
Old Oct 1, 2007 | 06:17 PM
macdiesel5spd
just purchased a frame mounted fuel pump from napa for 80.00. specs out at 45psi. it is for a 91 f-150 5.0L. wish me luck, i hope this works.
