need help with water seperator
Old Oct 14, 2007 | 05:46 PM
MauiRam's Avatar
MauiRam
Default need help with water seperator
When draining the water from the water seperator, am I suppose to drain all the liquid out or what? I drained some of it out and it was clear like water but smelt like diesel.I'm not changing the fuel filter but I just read on here that i'm suppose to drain the water every so often. Any help?
Old Oct 14, 2007 | 05:58 PM
jakebrake's Avatar
jakebrake
Default RE: need help with water seperator
you don't have to drain it all unless your changing the filter. Just drain a little into a bucket and see if there is any water in it.
Old Oct 14, 2007 | 06:16 PM
MauiRam's Avatar
MauiRam
Alright thanks man
Old Oct 14, 2007 | 07:41 PM
NCcummins's Avatar
NCcummins
how often do u drain the water on a FASS?
Old Oct 14, 2007 | 08:49 PM
NickBeek's Avatar
NickBeek
I am bad about following my own advise on this one but... I like to drain once a month at least.
Old Oct 14, 2007 | 08:56 PM
Joel_MD's Avatar
Joel_MD
Like Jakebrake said, you just need to drain a little. Water is denser than fuel, so if there's any water in the separater it will come out first when you open the valve.
Old Oct 14, 2007 | 08:58 PM
NCcummins's Avatar
NCcummins
so all you do, is once a month, open the valve on the bottom of the white caniter and let it drain out?
Old Oct 14, 2007 | 10:03 PM
jakebrake's Avatar
jakebrake
I never drain mine, I just replace the seperator at 15k. I dump the fuel out of it to check for water when I do, and the has never been any water at all. Never had any water ever from this fuel station in 2 1/2 years of fillin my truck up there. Looks like I found myself a good fuel station
Old Oct 14, 2007 | 11:43 PM
Mayfair's Avatar
Mayfair
Yeah, I've yet to drain my FASS either. It'll get drained whenI change the filters.
