Edge Juice/Attitude
Old Oct 19, 2007 | 11:14 PM
  #21
Bigriver's Avatar
Bigriver
Default RE: Edge Juice/Attitude
Wen re-studdingthe head, it sounds like it comes off and goes to a machine shop, not something to be done under a shady tree?
Old Oct 19, 2007 | 11:19 PM
  #22
sharx ram's Avatar
sharx ram
WHAT?
Old Oct 19, 2007 | 11:24 PM
  #23
Bigriver's Avatar
Bigriver
Sharx........when ya said I could float the head, I read that as blowing a head gasket. Isn't that corrected by re-studding the head?
Old Oct 19, 2007 | 11:45 PM
  #24
sharx ram's Avatar
sharx ram
Its worse than blowing a head gasket and yes, restudding it will take care of that possability.
Old Oct 20, 2007 | 12:03 AM
  #25
Bigriver's Avatar
Bigriver
OK, good to know, but I guess what I'm getting at is that when advancing up to the "hot" level on the juice, a few internal upgrades may be advised. Re-studding the heads, as you mentioned, what about the turbo, exhaust manifold, intake, intercooler, all that good stuff?
Would I be opening a can of worms in upgrades to handle the increase of power?
Old Oct 20, 2007 | 12:12 AM
  #26
sharx ram's Avatar
sharx ram
The turbo would be the only thing Id keep an eye on, it sounds like once you restud...everything else should be ok, watch your turbo tho
Old Oct 20, 2007 | 12:30 AM
  #27
gtxpooch's Avatar
gtxpooch
by sharxram
I get better mileage in Extreme mode...I cant figure that one out at all
How do you drive it? I keep mine under 2K rpm, and don't push it unless them powerchokes and duraslacks get uppity and wanna show off
Old Oct 20, 2007 | 12:41 AM
  #28
sharx ram's Avatar
sharx ram
I do mostly highway driving but have been running in mileage mode for the past 3 weeks at 16.9, then today went back to Extreme and she went to 17 and climbing and Iam driving at about 76 to 80 miles an hour
Old Oct 20, 2007 | 10:18 AM
  #29
Super Dave's Avatar
Super Dave
ORIGINAL: sharx ram
Doesn't it smoke more on the extreme setting at low RPMs? How do you have your low boost fueling set? I suppose a person couldturn the low boost fueling down on the extreme setting, but what fun is that[:'(]
Mine set to 5/5smokes a bit, so I usually keep it on the tow setting where it doesn't smoke thinking it should be getting better mileage.
So I take it that the only setting that really changes with the "hot" upgrade is the Extreme setting?--sweet.
Old Oct 20, 2007 | 11:10 AM
  #30
sharx ram's Avatar
sharx ram
ORIGINAL: Super Dave
ORIGINAL: sharx ram
No, all settings bump up, 3 now is what 5 used tobe. I run with my low boost fueling set to smoke the most in extreme mode. I dont understand why I get better mileage in extreme mode, "Bruce" must rather play than drive like a grandpa!
