If you had to start from scratch
Old 11-13-2007, 12:08 PM
dtb86001's Avatar
dtb86001
dtb86001 is offline
Default RE: If you had to start from scratch
I definantly have been looking at the cold air intake systems out there. I think i like the banks system the best. it has proven flow bench test data for the 2006 dodge truck. if i could get that Amsiol nano filter that would have that same oval opening as the banks filter i would get it in a second. Right now im like a kid in a candy store ther is so much you could do but i want to do it all.
  #22
Old 11-13-2007, 12:37 PM
pngmotoman's Avatar
pngmotoman
pngmotoman is offline
i havent done much to my truck but i know the next thing is going to be gauges then tranny so i know that i can get the other mods and hopefully not break something
  #23
Old 11-13-2007, 01:22 PM
sharx ram's Avatar
sharx ram
sharx ram is offline
Nice looking rig man Looks abit cold tho, I dont miss that...Id be at the car wash every other day hehehehe
  #24
Old 11-13-2007, 08:23 PM
woligator's Avatar
woligator
woligator is offline
rooster31: do u like ur HRVP44?? do u really think it worth the prices they ask for it?
is it killing fuel economy or only making more fuel available when u want it???
  #25
Old 11-13-2007, 09:28 PM
R0oster31's Avatar
R0oster31
R0oster31 is offline
Well I got bad fuel in NE when I was coming back from leave so I had to put in a new pump anyway. It doesn't kill mileage as the amount of fuel it supplies is still driven by how hard you get on the go pedal.
  #26
Old 11-14-2007, 12:24 AM
Johndcjr1989's Avatar
Johndcjr1989
Johndcjr1989 is offline
heres what i plan to do (slowly as money allows)
1. programmer
2. exhaust
3. intake
4. ATS Transmission
5. new turbo
6. injectors
and then see where that gets me. right now my goal is 500rwhp and 1200 rwtq. those mods should more than do it.
  #27
Old 11-14-2007, 12:42 AM
jakebrake's Avatar
jakebrake
jakebrake is offline
Yes you can replace the camshaft in these engines without pulling the head. first off you have to tear the front tin off which means removing grill air to air rad fan ect. Then youll need to pull the valvecover and all the rocker arms and puch tubes. Then you need to get dowls that are slightly larger then the push tubes and cut a slot in one tip. You then drive the dowls into the lifters. This will allow you to pull the lifters up and slid the cam out. Then you insert a piece of carboard or something in the cam bore to catch the lifters (or else you'll be pulling the oil pan). Pull the dowels and let the lifters drop on to the cardboard and pull them out. Thats the easy part, putting the new lifters in is a pain in the butt. Pretty much using string to pull them into place.
  #28
Old 11-14-2007, 01:31 AM
Mayfair's Avatar
Mayfair
Mayfair is offline
1. 4" exhaust
2. Some sort of newer intake
3. FASS
4. Gauges - boost, fuel pressure, pyro
5. Edge ( at least a Comp box )
6. Mag-hytec trans pan and diffs
Pretty much the route that I went.
  #29
Old 11-14-2007, 09:06 PM
beachmstr's Avatar
beachmstr
beachmstr is offline
Well, I just purchased my second piece. Did my exhaust and now I have bought my intake. So we're moving on. All together I'm only into it for $350 so far. This thready could keep going for a long time.
  #30
Old 01-02-2008, 07:24 PM
bluecummins's Avatar
bluecummins
bluecummins is offline
I would go with tranny upgrades all i no is one thing anything u do performance wise u are going to need tranny work and gauges go with the edge juice you cant go wrong.
Quick Reply: If you had to start from scratch
