toyo open country at
Old Nov 21, 2007 | 08:45 AM
carter's Avatar
carter
Default toyo open country at
Looking at a set of theseon my 05 3500 srw 4x4.Anyone have likes or dislikes about the toyo's?
Also thinking about steping up to 285 / 75 /17 . running 4.10 gears should this get me any milage increase or will I lose mpg?
Old Nov 21, 2007 | 09:05 AM
Drew's Avatar
Drew
Default RE: toyo open country at
leave your axels with the 3.73's. and run the 285's. just make sure to get your speedo reset.
Old Nov 21, 2007 | 09:14 AM
Aero Ram's Avatar
Aero Ram
On that If anyone could let me know milage on 35/12.50 w/3.73 failrly stock truckmpg results (hand calcplz)I would like to know as well since I plan on gettin some w/n a year or so...
Carter you might fill in your sig with any mods you have, as mods such as a programmer can affect you mpg a decent amount, this way everyone can relate more to your truck and give you results from other guys with similar mods
Old Nov 21, 2007 | 09:17 AM
Aero Ram's Avatar
Aero Ram
ORIGINAL: Drew
To add to that 285/75 17s will put you off about 2mph for every 30mph you do
ex. at 60mph you'll be runnin 64mph
Old Nov 21, 2007 | 09:31 AM
carter's Avatar
carter
Sorry guys filled in the sig. I have 4.10 gears Will switching from 265/75/17 to 285/75/17 help my mpg with the 4.10 gears?
Old Nov 21, 2007 | 09:41 AM
cujo's Avatar
cujo
ORIGINAL: carter
A little. I believe the only difference between the 265 and 285 is the 285's are 2 inches taller in diameter. A taller tire should reduce rpms a little.
Old Nov 21, 2007 | 09:44 AM
Drew's Avatar
Drew
you will gain mileage on the highway due to lower engine rpm, however you will loose city mileage due to a reduced mechanical advantage. . .however the difference between the two may cancel each other out depending on driving habits and how much time you spend at a constant speed.
Old Nov 21, 2007 | 10:05 AM
sharx ram's Avatar
sharx ram
I was just looking at aset yesterday, they told me to avoid them if I wanted any kind of mileage.
Old Nov 21, 2007 | 10:18 AM
carter's Avatar
carter
What gears are you running, and what kind of mpg are you getting?
With the 4.10 's I'm just getting 15.6 - 16 av. If I keep it 55 or under it will sometimes push 17. With the 4.10 you get to 2000 rpm at about 64 mph.
I was hoping the 285's would lower the rpm's and help mpg a little.
I envy those getting 18 - 20 mpg!!!
Old Nov 21, 2007 | 10:23 AM
sharx ram's Avatar
sharx ram
Im sorry, I should have worded that better...I meant wear mileage, not fuel mileage
