high idle***solution found!!!!***(see edit)
Old Nov 27, 2007 | 09:49 PM
ryans590's Avatar
ryans590
Default RE: high idle
so the factory high idle wont work without cruse?
ive herd of people putting a variable resister switch into one of the wires coming off the throdle petal...anyone ever herd of this?
Old Nov 27, 2007 | 09:58 PM
NickBeek's Avatar
NickBeek
I have seen a guy do that on a Ford, but never seen it done on a Dodge. The truck should idle up to about 1000 RPM on its own in cold temps. Mine doesn't do that too often because of where I live, but it has done it before. I beleive you need to have the cruise control to use the other controllable idle function.
Parts / Service, that clutch switch kit you were referring to adds a second switch to the clutch and all it does is run the ground connection from that pin on the ecm through the switch at the clutch. I got the switch kit from Cummins but if I had to do it again, I would just get the pin and ground it.
Old Nov 27, 2007 | 10:10 PM
ryans590's Avatar
ryans590
yah he said it idled up a little but not enough for where he is at....so with cruise he is SOL eh lol...anyone know how hard it is to add cruise?
Old Nov 27, 2007 | 11:58 PM
ryans590's Avatar
ryans590
so anyone know how to add a high idle without having cruise...cant imagen that they would charge to get that too....i dont imagen you can just add a hand throdle since its all electric right?
Old Nov 28, 2007 | 05:22 AM
XTRIK8's Avatar
XTRIK8
Someone said if you have an auto, you should run the high idle in neutral so tranny fluid will flow. I have not heard that andI have been running mine in park. Could i have done so damage???
Old Nov 28, 2007 | 07:51 AM
Super Dave's Avatar
Super Dave
It's possible. Your owner's manual says to let it idle in neutral if stuck in traffic, etc.
Old Nov 28, 2007 | 08:39 PM
ryans590's Avatar
ryans590
hmm anyone else got any ideas?
