Filter from He**
Old Dec 11, 2007 | 09:46 PM
burban2002's Avatar
burban2002
Default Filter from He**
I got done with the my first oil change in the CTD with amsoil 15w-40 and a stratapore filter, but first I had to take off the old filter. Holy crap, I think the dealer had a 500 lb ape put that thing on. I weigh about 150 lbs and I had to put all my weight into moving that thing and work on it for about 2 hours to get it to budge. When I finally got it off I saw that there was no oil on the seal which probably made it a crap load harder to get off. I tried a strap filter which dented it, a cap filter which stripped the bottom, and finally a regular wrench that loved to slide until it finally got some grip. The aftermath was a destroyed filter and skin vanished from my knuckles, but a fresh pan of oil. Anybody else have something like that happen to them?
Old Dec 11, 2007 | 09:59 PM
Ben D.'s Avatar
Ben D.
Default RE: Filter from He**
there is a thread in 3rd gen where a guy did his first oil change on a hemi and had an issue similiar to urs. my guess is the filter is put on at the factory by a machine that just does it fast and it ends up being too tight
Old Dec 11, 2007 | 10:02 PM
Kev_n_AZ's Avatar
Kev_n_AZ
I usually use my largest set of channel locks for a good grip! once its squished and turning, them my hands can finish
Old Dec 11, 2007 | 10:13 PM
Methos's Avatar
Methos
Yup. Welcome to the club. Went through 2 plastic cap wrenches, strap wrench, chain style wrench, and cracked 2 different steel ones trying to get mine off.... finally gave up had it towed to the garage for them to get it off. Took a pro about 45 minutes to get it to budge even. Should have heard the screech when it finally let go, I was 2 rooms away and heard it over the shop noise and through a closed door.
Old Dec 11, 2007 | 10:37 PM
jedrph's Avatar
jedrph
Oh boy, I'm just getting ready for my 1st oil change. I wonder if I should just take it to the dealer. We had that happen in a chevy caprice. We ended up with a large cold chisel through the damn thing, box end wrench around the chisel, and a pipe on the wrench for leverage to get the thing off. That's rediculous. Dodge needs to lower the torque on that robot!!
Just curious, is the oil pressure higher on a diesel than a gasoline engine? and does the filter need an extra full turn after finger tight??
Old Dec 11, 2007 | 10:43 PM
burban2002's Avatar
burban2002
The funny thing is thats its not a new truck so the tech had to put it on that tight. He really torqued that sucker down. Like methos said, it was pretty loud when it finally let go.
Old Dec 11, 2007 | 10:54 PM
handymanherb's Avatar
handymanherb
I allways taken mine off bare handed, but then I bought it with 25000 miles on it, so it had been done a few time allready.
I find just hand tight and I never had a problem with it leaking after doing the last three by hand
Old Dec 11, 2007 | 11:00 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: handymanherb
I did mine hand tight once, checked it one day out of the blue and found it to be a 1/4 turn or so loose. [:@]
now I hand tighten it, but with a kick!
Old Dec 12, 2007 | 12:05 AM
Ben D.'s Avatar
Ben D.
Yea definately hand tight is the way to go. I go hand tight and a slight bit past mebbe a quarter turn and consider it good. putting em on that tight can cause leaks sometimes. stupid that a tech would do that.
Old Dec 12, 2007 | 08:40 AM
Aero Ram's Avatar
Aero Ram
Just another reason why I do my own work unless its something that I have no clue on and can't figure out like why it took 3 tries to get the truck to fire up this mournin.... wierd...
A good way to break a tight filter as the one you described is to pull the motor for easy access and weld a 12ft pipe on the filter housing andget as many of your strongest buds to help turn it...that usually* gives you the torque to break it...
