View Poll Results: A poll
Voters: 111. You may not vote on this poll
Question about Biodiesel
#81
hey guys new to here but just wanted to give my limited 2 cents on bio diesel. I used it 2 times out in vegas when i was driveing cross country with my cimmins. I will say this about bio diesel i noticedthe truck burned twice as much. So for regular diesel the truck would burn lets say 20mpg, on bio it was burning 2 gallons for every 20mpg. That was with a load on the back of 8000lbs. The mpg are just for instance if anyone was wondering. So i tired it with no load on my way back to ct and it still did the same thing. The more i found out about bio diesel it s olny like 25% diesel and mostly water. Running 75 percent water thru there cant be that great for th motor I would imagine. Thats like putting oil in your gas tank yeah it will burn it but its a diesel it will burn anything pretty much lol there lol compression. Yah know. One last thing i did notice the truck didnt reall soot and it had 1/2 the power than normal
#82
I don't know what you had in the tank but it sure wasn't bio diesel and any bio diesel Ive ever made only looses 3% MPG and power, no more.
There is LESS water in ASTM bio diesel than petroleum based bio diesel, so your reading false and misleading information. SOunds like you had bad NON spec bio in there to me.
#83
#84
#85
Ridiculous to think that biodiesel is full of water! I wish I had a local station where I could buy it. I'm sure the Ultra Low Sulpher Diesel isn't good for my old timey 12v Cummins. I would happily use Bio at a 15 to 25% replacement ratio just to better lubricate my valves and pumps. I'm sure it would also be a great cleaner as well.
#86
I've made well over 100,000 Gallons of bio and running bad B-100 will clog your filter in a hurray and if not filtered down to 10micron could cause some problems, but other than that good clean bio when mixed up to B-80 has run in my truck hardly any problems. I say hardly, in cold weather it is harder to deal with. I have a 2001 24V HO 6 speed manual. This is one (if not THE) worst year of that truck IMO and even then, with some inexpensive add-ons the truck runs great on any mixture of bio.
However, I have recently discovered that the truck keeps almost all its power and MPG if run on a 70% WVO/30% Petro mixture rather than bio. I think every truck is a different situation as well, so to bash bio diesel in ALL circumstances or instances would not be fair to the bio fuels industry as a whole.
my .02 worth. Just a FYI, I've heard many times throughout the circles that the Ford/International 7.3L and the older Dodge pre 2000 are the best for the higher viscosity bio fuels.
Good luck to all.
Good luck to all.
#90
You know, Ive researched this stuff for years and have read and heard nothing but good from biodiesel. Burns cleaner,trucks run better. and have heard of mileage increases. For those of you guys that are thinking of making it, good luck, Just be careful of the methanol. Heres to not paying 3.00 at the pump!!!!
