stop and go or freeway...
Old Jan 15, 2008 | 10:59 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default stop and go or freeway...
driving ...
which is "best" for diesel engine warm up??
now we have discussed a 2 minute or so driveway warmup, then drive mellow for a bit.
how about stop and go city street vs freeway warm up in the cold mornings, nights, or any time....
for instance, the majority of you have an electrically controled clutched engine fan, where as I have a 100% "on all the time" mechanical fan.
the more times I spool the turbo, the faster it warms.
on the freeway, it wil take 10 miles or so to actually hit the temp for the t stat to open, then the guage drops and holds at norm temp.
surface roads, it varies depending on traffic pace.
so, which do you feel is better to "warm up to" for any of the ctds????
Old Jan 15, 2008 | 11:38 AM
UpBranchLiner's Avatar
UpBranchLiner
Default RE: stop and go or freeway...
I live on a county highway so I have to crank it up to 55 right off the bat. Some times it takes aawhile to finally shift into overdrive.
Old Jan 15, 2008 | 03:52 PM
Scott91370's Avatar
Scott91370
Keeping it under 2k until it's at least to 140* would be ideal. As far as stop and go or steady- I would opt for steady speed. The rpm's from starting off are going to be the toughest on a cold engine.
Old Jan 15, 2008 | 04:09 PM
Mayfair's Avatar
Mayfair
When I fire my Ram up, I usually wait a couple of seconds and roll on out. I'd like to wait the full 2 minutes, however because of the hill that I park on, I'm worried that the oil isn't getting evenly distributed so I pull away and just keep it below 2K until the temps move on up. It's really not that hard for me though since I'm light to light on my way to work.
Here's the pitch I park on...
Old Jan 15, 2008 | 04:14 PM
UpBranchLiner
Does it even fit in the garage Mayfair?
Old Jan 15, 2008 | 04:17 PM
Drew's Avatar
Drew
stop and go is hard on any engine. the constant speeds of the highway is actualy better since there is less wear on the engine.
Old Jan 15, 2008 | 04:18 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Mayfair...
you saying thet the drive way slopes negatively towards the garage door???
Old Jan 15, 2008 | 04:29 PM
Mayfair's Avatar
Mayfair
The way you see it is the way it gets parked every night. There is no way in hell that thing would fit in the garage.
My garage is pretty full anyway ...
Old Jan 15, 2008 | 04:36 PM
UpBranchLiner
Sure it will fit. You just have to back it in faster.
Old Jan 15, 2008 | 04:49 PM
Kev_n_AZ's Avatar
Kev_n_AZ
I will help you with that problem Mayfair.
the guys and I will ride out there and remove those old dusty "unused" bikes and other "forgotten" items from your garage.
no cost to you at all!
anything that we can do to help
