tach-o-meter install ??
Old Jan 15, 2008 | 11:06 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default tach-o-meter install ??
is there any way to connect a tach to my 1st gen ctd?
unlike the 2nd gen and later models, I have no ELECTRONICS (to a point) under the hood. the majority is mechanical.
I would like to see what my cummins runs at....
any ideas???
Old Jan 15, 2008 | 05:54 PM
triton's Avatar
triton
Default RE: tach-o-meter install ??
I think you would be able to mount a cam position sensor to run your tach. Since you have no electronics though... you'd really have to know what you were doing as there would be voltage issues you'd need to know how to deal with. It would be a complete custom job.
Old Jan 15, 2008 | 05:58 PM
Kev_n_AZ's Avatar
Kev_n_AZ
thanks Triton..
Old Jan 15, 2008 | 07:04 PM
BC847's Avatar
BC847
You have the OEM connector under the dash, taped to the left side of the steering column. Gimme a sec to find a pic.
Old Jan 15, 2008 | 07:12 PM
BC847's Avatar
BC847
Remove the little dash panel just below the steering column. Looking through the opening, to the left of the column ~
The OEM factory tachometer plug offers the following:
- 18ga Black = +12vdc for gage lights
- 20ga Orange = 12vdc Common
- 18ga Red = Switched +12vdc
- 20ga Grey w/light blue tracer = Tachometer Signal From PCM
Hope this helps.
Old Jan 15, 2008 | 07:17 PM
Kev_n_AZ's Avatar
Kev_n_AZ
are you kidding me??
so I could possibly just "plug" a new unit in?????
thank you very much BC847!!!!
Old Jan 15, 2008 | 07:32 PM
BC847's Avatar
BC847
I usedthe ISSPRO Tachometer in my heap (0~4000RPM, P/N ~ R5503).
If you choose to go this route, DO NOT purchase the companion ISSPRO hook-up harness. It is a universal harness for the ISSPRO line. The instructions as provided are bass-ackward and if you can figure it out without ruining stuff, you'll learn you don't need it at all. Just run the wires directly from the OEM connector to the tach.
ISSPRO also offers a 3000rpm model if you're that slow.
Old Jan 15, 2008 | 07:50 PM
Kev_n_AZ's Avatar
Kev_n_AZ
BC847
would you be so kind as to either post or link the specs for your rig.
I am interested, especially since it is a 1st gen like mine
pics are nice too
I will look for the ISSPRO tach..
thanks for the help!!
any idea on my dilema with the throttle???
https://dodgeforum.com/m_1129557/tm.htm
Old May 30, 2008 | 10:08 AM
mopar1_49735's Avatar
mopar1_49735
Where did you get your Tach mount for your 93? I read your recommendations on your Tach install and want to do the same. I'm going to go with the ISS proR5503 Tach like you did, but want the smooth look that yours has with the collum mount. Any sources on the Collum mount would be greatly appreceated. Thanks!
92 Cummins 4x4 55,000 original miles
99 Neon R/T
74 Dart 340 swinger
Old May 30, 2008 | 11:21 AM
cumminalong's Avatar
cumminalong
Not trying to steal your thread, but WHERE THE HELL WERE YOU 1st GEN GUYS WHEN I WAS ASKING FOR PICS FOR THE VIDEO???
I got all good pics and videos, except no first gen guys.
