2007 CTD How much oil ?
Old Jan 15, 2008 | 06:21 PM
roadracer18's Avatar
roadracer18
Default 2007 CTD How much oil ?
I just changed the oil in my 07 CTD 2500HD and added 12Qts of Amsoil. After running the engine for a cpl minutes and letting the engine sit for a cpl minutes the dip stick reads half way up the safe zone. Should I run it all the way up the safe zone or run the 12Qts and call it a day.
Old Jan 15, 2008 | 06:25 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: 2007 CTD How much oil ?
new or old, every diesel will run the oil level where it is most comfortable
(it will burn or other wise get rid of excess that is doesnt want)
if you are already in the "safe zone", add a tad bit. keep track of the level at every fill up to see if it changes.
then you should have an idea of what the engine likes.
Old Jan 15, 2008 | 06:50 PM
roadracer18
Thanks Kev
I let the track sit for 10 minutes and the level went up to the full mark. 12 qts it is.
Old Jan 15, 2008 | 07:11 PM
04QC4X4's Avatar
04QC4X4
Mine goes just over the full line with 12 quarts.
Old Jan 15, 2008 | 07:21 PM
Kev_n_AZ's Avatar
Kev_n_AZ
note:
large oil capacity requires more drain time to the bottom of the pan after shut down. I would wait 5 minutes, or the length of time it takes to fill your fuel tank at the pump ..
when I fill up, and after an oil change, I wait till the tank is full (at the pump)or its been long enough to go in the house and clean up from changing the oil..along with pickin up the drain pan, etc...
enjoy your CTD!!!
Old Jan 15, 2008 | 07:59 PM
Drew's Avatar
Drew
did you prefill the filter???
mine is normaly in the same area as yours after running
Old Jan 15, 2008 | 09:26 PM
reddodge98's Avatar
reddodge98
i never fill up the filter when i do an oil change on my 2005 diesel...are u supposed to??? i was recommended not to by CAT mechanics, but i do not know if cummins technicians recommend to or not.
Old Jan 16, 2008 | 09:35 AM
sddunn2's Avatar
sddunn2
we always pre fill the filter where i work on every diesel . that filter takes a lot of oil if you dont prefill it when you start it up the pump has to first fill the filter before oil gets to flow through the motor . metal on metal ouch as well on your truck i believe the turbo has oil in it as well dont want to burn that puppy out !!
Old Jan 16, 2008 | 09:40 AM
Drew's Avatar
Drew
you prefill the filter on any vehicle that has a turbo on it. . . when cold it may not hurt things as much. . .however hot it WILL do some dammage.
the stock filter holds right at a quart of oil.
