2000 3500 dually question
Old Jan 22, 2008 | 09:34 PM
allextremes's Avatar
allextremes
Default 2000 3500 dually question
I have a 2000 dodge ram 3500 4x4 diesel dually 1 ton and i have a thumping issue when i hit any bump. it is like something is coming up and hitting the floor pan. i can't seem to find anything loose underneath. i just replaced the track bar, pitman arm, and tie rod end 4 months ago and then i did the front hub assembly with bearings about 6 months ago. i started to notice this about a month ago when i put my meyers plow on. but this problem continues when the plow is off as well.
any help would be appreciated
thanks
brian
Old Jan 22, 2008 | 09:46 PM
gdwrnch33's Avatar
gdwrnch33
Member
Default RE: 2000 3500 dually question
HAVE YOU CHECKED BODY MOUNTS. THE RUBBER BUSHINGS COULD BE WORE AND LETTING THE BODY BUMP THE RAILS.
Old Jan 22, 2008 | 09:53 PM
soniclm's Avatar
soniclm
maybe could it be your ball joints? I have some nosie to that my truck makes when I hit bumps, I thought it was my ball joints and replaced all them and it wasn't
Old Jan 22, 2008 | 10:13 PM
jakebrake's Avatar
jakebrake
Mine made a clunking noise when I bought the truck,turned out to be the front shocks (they were still the original ones from the factory). Replaced them with a new set and the noise went away.
Old Jan 22, 2008 | 10:17 PM
soniclm's Avatar
soniclm
thats i may think whats mine is, its a contast nosie and my truck has bout 140,000 miles and they are pry factory
Old Jan 23, 2008 | 12:17 AM
Super Dave's Avatar
Super Dave
The other day mine was making a loud bang noise under my butt when I went over a bump. I finally remembered I had left the trailer hitch in the reciever. Once I took it out, the noise stopped
Old Jan 23, 2008 | 01:10 AM
6inarow's Avatar
6inarow
check to make sure the little rubber sleeves are still on your rear overload springs, my dually will do the same thing when i loose one, and i do lose one now and then, when that overload slaps the stop it sends that noise right down the frame and under your butt, the first time mine did it it took me forever to find it!
Old Jan 23, 2008 | 06:14 AM
woligator's Avatar
woligator
if i give a jab on the throttle its give a loud hit on mine under the floorpan,i cheked trans mount and all but i cant find it
Old Feb 11, 2008 | 01:44 AM
Snowmobile's Avatar
Snowmobile
I have the exact same noise as allextremes. Drives me crazy. I think I'll check my body mounts to see if the rubber is worn. If anyone else has this problem and has the solution please let me know. I bet it just might be the rubber bushings worn out. Good suggestion.
