Flushed the brakes today...
#21
RE: Flushed the brakes today...
You could get one of these through the snap-on website I suppose... but with a little running-around I'm sure you could get a lawn sprayer from home-depot to work just as well... I got the quick-disconnect from a MAC tool salesman. I would have attempted to make a lawn-sprayer version, but I like yelling at someone when something goes wrong, in this case... it's my snap-on dealer.
There's also the vacuum type bleeder, more popular for the domestic stuff... but I never have liked them.
http://buy1.snapon.com/catalog/item....mp;dir=catalog
#22
$220.00 smacks ?!?!?
Man they sure are proud of that thing huh ??
Description:
One gallon capacity unit features a self-contained, hand-pressurized pump, more than 10' of hose with shut-off, pressure gauge, and quick coupler for use with other brake bleeder adaptors (such as any of the BB300B Adaptors). Use only D.O.T. 3 or D.O.T 4 Automotive Brake Fluid with this brake bleeder. Do not use any other fluids, oils, chemicals or solvents.
Product Specifications
Stock #
BB100B
Name
Brake Bleeder, Nondiaphragm-Type
Price**
$221.35
Brand
Blue Point
[hr]
Check this one out
http://www.harborfreight.com/cpi/cta...emnumber=94219
TWO GALLON SPRAYER WITH 4 FT. HOSE
Use this versatile sprayer for stains, sealers, pesticides or weed killer.
[ul][*]Two gallon capacity[*]Lightweight yet durable poly tank will not corrode[*]Hand operated pump[*]Funnel top for no-spill easy filling[*]Pressure release valve[*]4 ft. hose and convenient shoulder strap[/ul]
ITEM 94219-4VGA
$14.87 Email link to a friend
Description:
Stock #
BB100B
Name
Price**
$221.35
Brand
Blue Point
[hr]
Check this one out
ITEM 94219-4VGA
#23
And it comes with a convienent shoulder strap... it's a bargain! [sm=bling.gif]
Brake fluid is brutal on plastics, but so is weed killer... What could possibly go wrong...
With the $221.35 Blue Point you get some brass fittings and a pressure gague.
Another product that advertises shoulder straps...
She wants out of that thing.
#24
#25
Check this out from Harbor ...
BRAKE FLUID BLEEDER
Convenient one man operation with no specialized brake reservoir cap needed. Draws fluid from brake nozzle enabling brake bleeding or full replacement of fluid system. Includes brake fluid bleeder, fluid reservoir with twist valve and four master cylinder adapters.
[ul][/ul]
Capacity: 34 oz., Adapter sizes: 21 to 30 mm, 24 to 32 mm, 28 to 37 mm and 32 to 41 mm; Air requirement: 90 to 120 PSI, Air inlet: 1/4'- 18 NPT, Weight: 1.5 lbs.
ITEM 92924-0VGA
$29.99 Email link to a friend
BRAKE FLUID BLEEDER
[ul][/ul]
ITEM 92924-0VGA
#26
ORIGINAL: steve05ram360
that is slick! one thing though... when you push in the new fluid and force out the old fluid do you end up mixing much before it comes out clean? I ended up draining my resiviour down pretty low before putting in fresh fluid to minimize the mixing.
#27
ORIGINAL: Mayfair
BRAKE FLUID BLEEDER
[ul][/ul]
ITEM 92924-0VGA
BRAKE FLUID BLEEDER
[ul][/ul]
ITEM 92924-0VGA
Someone who does two to five brake flushes a day (yours truly) has gotten used to the other one.
#28
I'd like to make some sort of combination of the two. I like the way the one that you have works, however i don't see me buying a gallon of brake fluid to use it. That's why I kinda like the littler one. If I could make some sort of combo of the two, that would be cool.
